Does this sound like a bad fuse box?
Ok so now i'm adressing my electric problems on my 88 F150, I had 2 bad fuses, now replaced.
Now if I open the door and step on the brake pedal, the buzzer buzzes.
When the door is closed, when I put my left turn signal, the buzzer buzzes with the flasher! So does the dash cluster light, and 5 roof cab lights and the right turn signal flashes also, but pretty dime.
There has been one hellava electrical job done on this truck, but acually begining to think it should be fine....
Could this be a messed up fuse box? Or probably not grounding well or what?
on
here's the section of the forums that id try:
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Yeah I'm leaning towards a ground issue as well at this point. Following the schematics I'm not seeing anything staring at me off the bat. Primary one to check would be the firewall to engine ground by the wiper. Hey I've burned one of them up before too! Except in my case that was how I found out the previous owner changed the battery ground from the engine block to the core support. Was trying to crank that 5.8L gasser over using that teeny 8 gauge body ground!
Onus
46
01-05-2016 08:38 PM
mikefred44
06-02-2015 07:56 AM
reamer
18
10-10-2014 01:00 PM
reamer
06-04-2014 11:36 AM
DUALLYNOTED
11-01-2010 12:59 PM
