1978 - 1996 Big Bronco
'94, EEC self test codes...help
Old Dec 13, 2010 | 05:51 PM
igotoneforya's Avatar
igotoneforya
Bronco is acting up...engine bogs at half - 3/4 throttle...tps and MAP replaced...thinking its fuel pump...tested low key on, engine off, 29 psi at idle up to 3000 rpms....changed fuel filter, ran perfectly until i shut it off, cut out again after next trip (sat off for 4 hours after fuel filter change)
codes-
111- so thats good
then 1-1-8-1-6-2-8-1-8-1-6-2-8
How do I know if its 3 2-digit codes or 2 3-digit codes?
The 2 digits point to IDM
the 3 digits are rt side lean at part throttle and converter issue.
I am thinking either pump or computer is next...issues all point to TPS but that was not the fix I hoped for.
Old Dec 13, 2010 | 09:22 PM
greystreak92's Avatar
greystreak92
Ok, 29 PSI is NOT high enough to maintain fuel system pressure. 35-40 is minimum. If the filter and regulator are good, the pump is indeed suspect. And remember the pump is electronic so rpm has no effect on pump output. Fix this first.... THEN...
If its giving you code 111 then ALL of the Codes are three-digit. The ECM does one or the other, not both. There is a 2 second break between codes and they are flashed out twice in a row.
Keep in mind you have the ID code that flashes out BEFORE the fault and continuous memory codes. The ID Code indicates the engine size. One flash per pair of cylinders. So, a V8 would be four flashes... a 6 cylinder - three and a 4 cylinder - two flashes.
If you look at it that way, your initial ID Code of 4 flashes leaves you with the same two Codes flashed out as they should be... Code 181 and Code 628.
(For the record, two-digit Codes won't work here anyway as Code 28 does not apply to any of the equipment actually used in your truck. It references the VAF and certain dual spark plug versions of the EEC-IV system).
Code 181 - System at adaptive limits during partial throttle bank one lean. There is a very tedious test to make certain whether or not the O2 sensor has failed or not however, since this is the only Code of any consequence related to engine performance the most likely culprit is a failed O2 sensor.
Code 628 - E4OD fault Code related to transmission operations. Unless you are experiencing shifting issues or suspect the transmission is overheating, disregard this Code unless it comes up again after you have cleared codes and driven the truck for about an hour.
f100guy
62
Feb 2, 2026 04:15 PM
EasyDawg
Jan 21, 2017 11:05 PM
AGrayson84
2004 - 2008 F150
Nov 7, 2016 09:24 PM
Brad Felmey
Aug 4, 2011 03:06 PM
cwatkin
1997 - 2003 F150
Mar 28, 2011 12:57 PM
