Starting with synthetic oil!
My DD yota wouldn't start this morning(236,000miles on it), so I had to take the truck. It was below 20 degrees out and had been a cold night. The truck started right up and no romps! I'm impressed with the difference the T6 Rotella makes.
Also, the truck had been sitting for 4-5 days since I last drove it.
no plug
Clint, those temps are without plugging in for me as well, -15 is as low as I have tested not plugging in, but I would guess -20 or -25 is doable without plugging in. All new GP's at 120,000 miles, all batteries clean and nolaxed, all grounds cleaned, DK in fuel, fresh air filter, fresh fuel filter, and the syn oil and its a regular winter machine.
on
Fuel Economy
I haven't seen any savings in fuel economy, it would have to be miniscule if at all. i get 16 mpg on summer fuel, and 15 on winter blend running around MT at 80 mph, maybe if I slowed down i would see it, but the only thing that seems to change my fuel economy is when winter blend hits the tanks in October here. I switched to syn mid november this year, and it didn't change, still 15mpg.
On the flip side, that easy roll over is most likely adding longevity to my starter and batteries, as well as my power bill that you mentioned.
That one synthetic oil change a year saves me plenty of green, but the peace of mind that my truck is going to start when I walk outside into the blizard we are currently having this very moment is priceless.
I used to drive a 98 Tacoma
I ran Mobile 1 5W-30 in it all the time, started up every winter day in Chicago winters!! I run Shell Rotella 15W-40 in my Powerstroke! but many run Shell 5W-40 with much success
