Door locks
Old Dec 13, 2010 | 08:31 AM
MikeB 88's Avatar
MikeB 88
Door locks
Lately when trying to unlock my driver door with the key it will act like it's the wrong key. I need to rotate it back and forth before it unlocks. Before I spray some grease (white lithium) sprayed in the key hole, I was wondering if it could be locking up further in the door? My truck doesn't have power locks.
Old Dec 13, 2010 | 11:10 AM
pawpaw's Avatar
pawpaw
A dry powered lock lube, is preferred over grease, as it'll attract & hold dirt that'll gum up the tumblers over time. The grease will get really hard in winter & won't allow the tumblers to function, so I'd not go there.
My lock will do that on occasion & I've had luck with spraying the key with WD-40 & inserting it in & out several times, to wet the lock tumblers.
If that doesn't do it, maybe try spritzing a little WD-40, or Silicone spray into the lock. No need to drench it, a little dab will do ya, then insert the key in & out while attempting to turn the lock.
I've also had luck first turning the key clockwise, then reversing direction & most times it'll then unlock. When I begin to have to do this often, it's spritz time again!!!
Some thoughts for consideration, Let us know how it goes.
Old Dec 13, 2010 | 03:39 PM
MikeB 88's Avatar
MikeB 88
Thanks for the heads up about the grease!! I have to do the same thing, turn the key clockwise first.
Old Dec 14, 2010 | 12:09 AM
mfp4073's Avatar
mfp4073
Mine did this too. both when I bought the truck about 4 years ago and about a year ago started to do it again. Think its the pins that are getting stuck. Little wd40 works great.
Old Dec 14, 2010 | 07:36 AM
MikeB 88's Avatar
MikeB 88
Going to do it today, right after waterless bath!!
Old Dec 14, 2010 | 05:08 PM
mdr617's Avatar
mdr617
graphite oil works best for door hinges, locks, and stuff like that. Every autoparts store has it, it is in a small can that looks like wd40
bandlgeorge
Oct 18, 2010 12:09 AM
DSMMH
Mar 8, 2010 11:01 AM
powrstrkn
Electrical Systems/Wiring
Oct 21, 2001 11:21 PM
