Sponsored by: Real Truck
Tire Size help
Old Dec 17, 2010 | 10:53 AM
Thrak1138's Avatar
Thrak1138
I have heard good things about the Nittos. I'm looking for a good mix between taller & wider.
Old Dec 21, 2010 | 05:18 PM
MacGSX's Avatar
MacGSX
Well I installed the Duratracs (315/75/16). So far so good. The sidewalls are very weak(could be because of the narrow rims: stock Lariat rims.). A quick jab to the wheel and the truck leans on them, doesn't feel to good. Also have some minor rub on the leaf springs but it's not bad AT ALL. The only problem I have that needs to be fixed is on the front driver side tire. It rubs the inner fender well when turning slightly. It's only plastic but I need to do something about it. Pictures to come tomorrow.
Old Dec 21, 2010 | 05:39 PM
Lubbockguy1979's Avatar
Lubbockguy1979
it will self clear out in a few miles. mine did.
Old Dec 30, 2010 | 06:42 PM
Lubbockguy1979
ok stumbled across the pictures. though i had deleted them from the puter. i added them to my albums as well but here they are
on the last picture you can see where it rubs the spring. it did rub the inner fender well for a day or two but i self cleared the area after a few turns. in the rear i used a zip tie to pull the rubber flaps back a little bit but it really want a issue
Old Dec 31, 2010 | 05:07 PM
Thrak1138's Avatar
Thrak1138
Those are good pics! Are those the 315s? on a 16" rim?
Thanks for posting those!
Old Dec 31, 2010 | 05:24 PM
Lubbockguy1979
Yse stock wheels and stock ride height. I liked the set up. I will probably end up with 35" tires on the 06 in a year or so when the stockers are done.
aj1434
Dec 22, 2016 05:36 PM
corn-dog
Apr 7, 2012 07:44 PM
dylan1952
Nov 4, 2011 10:05 AM
OldBlackCat
Aug 6, 2011 06:08 PM
motopsyko32
Jul 6, 2010 04:50 PM
