Offroad & 4x4
1976 F150 4x4 front suspension question
Old 12-11-2010, 11:48 PM
craigs2k's Avatar
craigs2k
craigs2k is offline
I am in the process of rebuilding the frame of my 76 f150 and don't think this is the stock front suspension(as far as the shock towers are concerned). The end result will be a 460 and a small lift, maybe 4". Can anyone point me in the direction of where to find maybe a dual shock setup and new spring buckets? Or maybe some aftermarket parts, custom stuff etc. Thanks in advance
Pic of the front suspension before
Frame as it sits now
Old 12-12-2010, 02:05 AM
fatdan460's Avatar
fatdan460
fatdan460 is offline
that is stock for a single shock setup, but someone must've torched some rivets and bolted the shock mounts back on.
idk where to find what you want for sure, but Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale is always a good place to start.
*jeffs bronco graveyard.
Old 12-12-2010, 02:56 PM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
Thats a 76 F150 shock set up on top the coil bucket and a 77-79 style shock mount bolted on behind the coil bucket.
Look on boncograveyard.com for aftermarket spring and shock mounts but nothing really custom. You'll either have to build something on your own or make somethng off another year work for anything different.
ccarrier
50
07-22-2019 04:25 PM
Jaime74656
16
02-04-2015 05:33 PM
dsgb
03-08-2013 07:47 PM
Howell05
13
04-23-2012 03:53 PM
Bowman85merc
180
04-22-2012 09:37 PM
Quick Reply: 1976 F150 4x4 front suspension question
