rear brake calipers???.....
Old Dec 11, 2010 | 08:37 PM
Talyn's Avatar
Talyn
I don't think I ever recall seeing this, but guy has a 99. door tag says 10/99 for mfg date.
The calipers on the rear axle are opposite of each other?
his other NBS 7.3 isn't that way.
Was this a 99 thing?
Old Dec 11, 2010 | 08:56 PM
F350-6's Avatar
F350-6
You mean like upside down or one in front and one in back? 10/99 is a late 99 so it should be the same as the rest of the NBS trucks. Built in 98 are the early 99's that have a few differences here and there.
Old Dec 11, 2010 | 09:09 PM
Talyn's Avatar
Talyn
yeah. Sorry
one caliper before the axle, and the other in front.
My 02 has them both in the same position, and his other SD was the same.
I was dumbfounded why it was like that.
Would twist the axle when pressure applied.
I'm pretty sure it said 10/99, but i guess it coulda said 10/98.
Hard tellin.
I'll ask clay when I see him as well.
Old Dec 11, 2010 | 09:23 PM
mueckster's Avatar
mueckster
I have seen this arrangement on the early '99 SD. The local electrical power generating station bought a fleet of them back then. The ones, I've seen had them mounted that way. IIRC, my nephew's e'99 F250 had the same configuration.
Old Dec 11, 2010 | 09:26 PM
bcaughhorn's Avatar
bcaughhorn
mine is that way
Old Dec 12, 2010 | 07:55 AM
megawatt00's Avatar
megawatt00
I have seen it once before and it was on a E99 as well.
Old Dec 12, 2010 | 09:31 AM
Fat Diesel's Avatar
Fat Diesel
Mine has a caliper in front of the wheel on one side. There was a recall about ten years ago or so but I wasn't worried about it so I didn't take it in. It is a little more vulnerable in front of the wheel.
Old Dec 12, 2010 | 11:00 AM
Shake-N-Bake's Avatar
Shake-N-Bake
My build date is 05/99. Left rear caliper is in front of the rotor and right rear is behind. There is a massive guard around the caliper. Must be ok that way because I have never had any issues in 260k miles ( knock on wood...)
I consider my truck a "mid year 99" model because it has late 99 power train and early 99 suspension components.
Old Dec 12, 2010 | 12:20 PM
pwstroker69's Avatar
pwstroker69
Just checked and mine is that way also, man'fd 04/99. One forward, one aft.
Anybody know if it was a diff caliper setup for other 99/00 models? I just ordered rear calipers and they are en-route. Now you got me worried I might not have the right ones.
D.
Old Dec 12, 2010 | 08:30 PM
Talyn's Avatar
Talyn
Thanks guys, good to know.
It needs a new rear axle.
he took it to shop to have new bearings put in and such cause the carrier was moving.
It wore a ring in the shim and he bought new shims for the guy to put in and the guy put the old shims in and didn't set the backlash properly. So it's just trashed.
I'll just find a later gen3 10.5 and throw it in for him then.
Talyn's Avatar
Talyn
frankiethethumper
Jan 25, 2020 12:08 PM
xmontex4
Jul 8, 2015 11:27 AM
bigtexan99
Oct 24, 2014 01:14 PM
SOLOLUCKY
Aug 14, 2013 08:59 AM
69ford99
2004 - 2008 F150
Aug 21, 2008 04:44 AM
