diesel problem
Old Mar 3, 2003 | 08:16 AM
skandiaman's Avatar
skandiaman
diesel problem
My 1996 7.3 psd will chug while driving. That is it will be running fine but then almost quit running for a second before starting again. I'm guessing this may be fuel as it will do it any time of the year and usually during the first 5min of running. It will also quit running totally while parked in idle after running for a while. Now the strange thing is it will also chug or die altogether on occasion if I open the door fast or close door fast with all windows up. Could this be a vacume thing? Any info. would be helpful. Thank you.
PS- besides this problem it always starts and runs excellent.
Old Mar 3, 2003 | 04:44 PM
alanscott's Avatar
alanscott
diesel problem
https://www.ford-trucks.com/forums/s...threadid=23617
https://www.ford-trucks.com/forums/s...threadid=23767
https://www.ford-trucks.com/forums/s...threadid=24683
Browse through these older threads, it's possible that you might have a bad cam position sensor.
The vacuum is created by the power steering pump, I don't see how that would cause a mis.
Welcome to the Site, and don't be bashfull about asking question
Old Mar 3, 2003 | 06:14 PM
martyfowler's Avatar
martyfowler
diesel problem
The vacuum is created by the power steering pump.
on my '96 psd the vacuum is created by the belt driven vacuum pump, am i right.
Old Mar 3, 2003 | 07:09 PM
bilder12's Avatar
bilder12
diesel problem
I dont know what year the conversion took place from the belt powered vacuum pump to the power steering pump making vacuum, but I dont understand how that would affect the operation of the engine, i.e. making it shut down or starve for fuel.
I dont know where you are from, but it sounds like fuel gelling problem or an O ring in the fuel filter is not quite right and allowing air into the system.
Is there any appearant fuel leaks around the valley of the engine?
Have you drained the fuel filter of water lately? Have you completed any mods to the computer and it isnt bolted in properly?
Just some things to look at ..........
Keep us posted.
Old Mar 4, 2003 | 12:39 AM
martyfowler
diesel problem
i was not aware that there ever was a power steering pump setup that made vacuum also. tells you how much i know about diesels. since i have found this site i learn something new every day.
