Fuel Leak
Old Dec 18, 2010 | 09:18 PM
  #31
themulchman's Avatar
themulchman
I found a leak on mine today after replacing the fuel pump this spring. It leaked all summer and never caught anything on fire. :-) The leak became really bad and with fuel at 3.35 a gallon, time to fix it. The fuel was coming from around the top of the water/fuel seperator valve. When I opened it with the engine running it almost squirted out. Replacing that valve and some of the other "O" rings on the sensors this week. Hopeully this will end the leak for good.
Old Dec 18, 2010 | 09:26 PM
  #32
Iallwork's Avatar
Iallwork
Welcome mulchman. How many miles you have on your truck.
Old Dec 18, 2010 | 09:46 PM
  #33
Tater50's Avatar
Tater50
Bad Weather
Still a no go for me: went to Ford for the O-rings; TOO high; I about passed out; if I do it myself, will contact one of the vendors on the board here to purchase the O's. They did not even have O's for the Water Drain valve.
Will update ASAP.
Later/Tater
Old Dec 18, 2010 | 10:42 PM
  #34
themulchman
I tried AutoZone, Advanced, NAPA and CarQuest. Only Ford had the valve. I don't think I'll try rebuilding it with new "O" rings. Time is money to me. This particular truck is a 95 F350 dual rear wheel, dump chasis. She has well over 300K. Original engine, on it's third manual tranny the rear has been rebuilt too many times to rebuild it again so I am on the second rear end.
Old Dec 19, 2010 | 07:37 PM
  #35
fleetsidebob's Avatar
fleetsidebob
Fuel Leak solved-I hope
My leak was at the fuel return nipple at the back of the engine, just below the turbo. At least that was what I was told that piece was. I got an O-ring from Ford ($8) and I backed off the fitting hoping to be able to have enough play to replace the o-ring. Well, that wasn't going to happen and it would entail removing the other end of the fuel line from the injector pump and removing a bunch of turbo pieces to get to it. Not having enough time to do that, I coated the threads with Teflon sealant, tightened it back up and let it sit for a day. Started it up tonight and no leak. Hope that does it. Unfortunately, it doesn't sound like that fix would work for any of the leaks everyone else is experiencing.
Old Dec 24, 2010 | 06:36 PM
  #36
Tater50's Avatar
Tater50
Final Update
Finally got repaired!! Here is the news: I detected that the WIF & the Fuel Heater O's were leaking by placing some paper towels under that sector. Also could see some very slight seepage near the pump.
Our local county school bus technician works on 7.3's all the time & has his own shop.
Due to weather; no shop & having to have a venogram, I decided to get him to do the work.
Final Info: replaced fuel pump, fuel filter heater & O's @ WIF & Fuel filter heater. Also in the deal I got an IPR & an ICP (for my 97 that needs work).
No leaks & runs great. Thanks for all the input. 2 Vehicles running, 2 more to go.
Later/Tater
Old Dec 24, 2010 | 08:30 PM
  #37
Iallwork's Avatar
Iallwork
Tater, Glad you found your leak, or leaks! There are so many places that fuel can leak. To just say there is one thing that always leaks would be a lie. I had a guy tell me to just give up I would never find the leak . I didn't listen and now, like you I have no leaks. Thanks for sticking with it and I hope you stick with FTE and help to solve other peoples problems. We are not always right. But its cheaper then paying some mechanics to screw things up and wonder if you got the shaft. Merry Christmas. Keep on posting brother!
Old Dec 25, 2010 | 07:19 PM
  #38
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Yes sir, glad to heard that you fixed the leak. and for the update.
renoduckman
Aug 17, 2014 10:40 PM
firemanpat29
Mar 24, 2014 07:24 AM
niko48
Aug 24, 2010 05:32 AM
Lushman
Jun 1, 2010 11:45 PM
theangryviking
May 20, 2008 09:20 PM
