diesel leak, need help
Old Mar 24, 2014 | 07:07 AM
firemanpat29's Avatar
firemanpat29
I have an 07 6.0 190,000 miles. its started leaking diesel, seems to be only when motor is running. leak is some where at upper filter. don't think its the filter o-ring I think it is below that where the fuel line connects to the filter assembly. looks like 4 torx screws bolt to the filter. anybody have any ideas? is there o-rings or a gasket between there? anyone have a parts breakdown of the upper filter area ? thanks
Old Mar 24, 2014 | 07:19 AM
mustang_309's Avatar
mustang_309
<p>
</p>
<p>That is the fuel pressure regulator and there is a gasket on the cover, you might as well get the updated blue spring kit and install it since you need to remove the cover to install the new gasket. The kit comes with all the required orings and gaskets.</p> Here is the link to riffraff diesel, http://www.riffraffdiesel.com/ford-fuel-pressure-regulator-blue-spring-kit/
Old Mar 24, 2014 | 07:20 AM
firemanpat29
THANKS ! I just found a utube video of the procedure seems pretty simple
Old Mar 24, 2014 | 07:24 AM
mustang_309
You can get the kit here, http://www.riffraffdiesel.com/ford-fuel-pressure-regulator-blue-spring-kit/
FreeDevin
Jun 13, 2015 09:23 AM
F250MAMOU
Nov 19, 2012 08:21 AM
Ratdog
Nov 10, 2010 12:02 AM
Olddog66
17
Nov 18, 2008 08:22 PM
dakejh
Sep 6, 2003 10:00 PM
