weird start up...
Old Dec 10, 2010 | 11:49 AM
Chippenwhales's Avatar
Chippenwhales
weird start up...
i just changed both batteries and the alternator ( thank god paz works at checkers-at her employee discount it was under $275.00 out the door for everything ! ) and everything seems good now-but...when i start the truck in the morning ( cold-well, cold for hawaii. 70 degrees or so...) i turn the key and step the gas peddle once to set the hi idle, when the wait to start light goes out i turn it over and it fires immediately, but then for the first 3-5 seconds it acts just like it does when you gonna run outta gas-the idle jumps and skips, just a bit, ( rpm surges, then resurges,etc...)and after a few seconds it runs like normal. no issues while driving, and it dont do it on warm restarts. just the innitial cold start. it wont die or anything, just seems weird as it has never done that before. hope its not a 'harbringer of doom' symptom. any ideas ? thanks to all.....
Old Dec 10, 2010 | 12:05 PM
thomabb's Avatar
thomabb
I don't think you should be stepping the gas pedal. Try starting her without doing that.
Old Dec 10, 2010 | 02:05 PM
Scratcher's Avatar
Scratcher
Hes only stepping on the gas pedal to set the high idle solenoid plunger for cold starting. Keeping the pedal depressed would be wrong. But depressing it and letting go before start-up is the normal procedure for an IDI.
Sounds like air intrusion to me
Old Dec 10, 2010 | 02:19 PM
thomabb's Avatar
thomabb
That falls in the "I did not know that" category. Learn something new every day, I guess.
Is 70 degrees really a cold start?
Old Dec 10, 2010 | 02:58 PM
Scratcher's Avatar
Scratcher
Not really. You should be able to start it without GPs at that high ambient temp but it does put a little bit of extra strain on the starter which is more difficult and expensive to replace than a set of GP's. Direct injection diesels will start easier without GPs than IDIs because there is no pre-combustion chamber in the head but its always better to use the GPs.
Old Dec 10, 2010 | 03:43 PM
johnboggs21's Avatar
johnboggs21
Sounds like air in the lines to me.....
Old Dec 10, 2010 | 04:33 PM
Chippenwhales
i just did all the return lines and fittings, t-caps, o-rings, etc 5 months ago-and the truck starts on a dime, just snorts a little for the first 5-10 seconds. and only first start, all other starts thruout the day ( even 5-7 hours later ) are 'normal', no surging.
Old Dec 10, 2010 | 04:40 PM
mabc926's Avatar
mabc926
Run some diesel kleen in the fuel and see if that helps.
Old Dec 10, 2010 | 05:13 PM
JHoffman93's Avatar
JHoffman93
I second the diesel kleen. My truck was hard to start when cold. I replaced the batteries, battery cables, glow plug controller and glow plugs, and installed an electric fuel system and it still started hard. Most of the things I changed needed to be changed anyway but non of it fixed the hard starting. Then I ran a bottle of Amsoil Injector cleaner through it and it has been starting great for over a week now and the temperatures at night have been dropping down into the 20's. Saturday night will be the real test, its supposed to drop down to about 10 degs. F.
Old Dec 13, 2010 | 07:09 AM
NorthernDiesel's Avatar
NorthernDiesel
Both wrong. Hold the pedal halfway while starting (Until it starts) and fully down when very cold (Below freezing).
This is also what is specified in the manual for the IDIs. Don't kill your starter cranking. Don't forget this is mechanical diesel injection, the gas engine rules don't apply.
Old Dec 13, 2010 | 07:50 AM
1994F2507.3L's Avatar
1994F2507.3L
to go even further.
in the ford diesel engine supplement for a 1994.5 and previous 7.3L Diesel Indirect Injected Engine your supposed to mash the pedal to the floor 1 time to set the high idle then release and then push the pedal halfway down if above freezing and all the way down below 32 degrees like northern said
Old Dec 13, 2010 | 08:22 AM
Scratcher's Avatar
Scratcher
Originally Posted by 1994F2507.3L
to go even further.
I know what the manual says, but consider what is happening in the cylinder bores, upper pistons and cylinder head on that first surge of revs on start up. Unlubricated metal is grinding on unlubricated metal because there is no oil pressure for the first few tenths of a second. Most engine wear occurs on startup because of low oil pressure simply because there is no oil in the upper engine area. That initial high rev surge is shaving metal from the cylinder walls not to mention what is happening in the head.
The high idle should be sufficient to get the engine running if your cold start advance, high idle and glowplugs are working properly.
My truck has been starting this way with no problems at 7f (-14c). Replacing a starter costs a couple of hundred bucks compared to several hundred for engine and head work.
Old Dec 13, 2010 | 08:39 AM
NorthernDiesel
Thanks 1994F250, I was recalling that supplement, didn't have the exact wording in mind!
That'll fix your starting problem right up! I actually struggled with that one for the first while I owned this truck.
Scratcher, sure, if its not needed; but if your truck is not starting and you give it enough to start that isnt making it madly rev.
If you know your throttle and your engine you can start with heavy throttle and pull it back as it starts up without letting it fly. Yes, you dont literally follow the manual and hold it to the floor and fire your engine to 3000rpm without using your head. That doesnt mean you chug away with no throttle and a struggling start.
You may be able to tweak this and that for a smooth start in the warmer areas but where it gets cold, there's no way high-idle only starts are going to work all year around.
Old Dec 13, 2010 | 08:58 AM
Scratcher's Avatar
Scratcher
Well I just ate my words. Its minus 11c here now and she would not start............................................. until I floored the pedal! lol
Old Dec 13, 2010 | 12:30 PM
NorthernDiesel
Haha... yea after I smoked out my friends and coworkers for a whole season I had a moment of sudden realization and that I needed more throttle on... oops!
