wierd starting problem
Old Mar 3, 2003 | 12:02 AM
oldfordtrucksrule's Avatar
oldfordtrucksrule
got an 83 f100. replaced the key lock cylinder because it was wore out. the ignition was always hard to turn when it was cold so i replaced the ignition switch after the lock. got the new switch from napa and its just as hard to turn as the old one. when it gets cold like below 10 degrees its all you can do to turn it to start. i mean you almost have to put pliers on it. the new napa switch doesnt turn easy, why? i even put electrical grease in the old one (switch, not cylinder) and it doesnt turn any easier. the only thing i can come up with is that its made that way or ive got a bad switch from napa. its adjusted right, just hard to turn and it gets really bad cold. its a non tilt column. anybody who replaced their switch have the same problem?
Old Mar 3, 2003 | 07:18 AM
steve83's Avatar
steve83
The lock cylinder pushes a gear rack that's packed with old, dry, dust-contaminated grease. Pull the steering wheel & the column shroud and spray around the wheel lock pin thoroughly with carb cleaner (put a catch-pan in the floor), and pull the lock cylinder again, and shoot inside there, too. Then spray in fresh white lithium grease. It'll be slick as whale $#!+.
Old Mar 3, 2003 | 12:03 PM
oldfordtrucksrule
ok let me try this again. i've replaced both the key cylinder and the ignition switch. all of my resistance is in the switch. i disconnected the rod that connects the cylinder and the switch at the switch and the lock moves effortlessly. problem is in the switch itself, its too damn hard to turn new out of the box
Old Mar 3, 2003 | 01:41 PM
Franklin2's Avatar
Franklin2
I just put a new ignition switch on my 1980, and it's not hard to turn. I put wd40 on the upper column like steve said, and it fixed my cold weather stiffness. I replaced the switch because of another problem I thought I had, and it turns out I like the new switch better than the old. The "off" position seems more positive. By the way, the switch I bought came from advance auto. I don't know if it's considered the cheapie version, but it's not stiff like yours.
Old Mar 3, 2003 | 08:09 PM
steve83's Avatar
steve83
So you don't think it's in the drive gear, upper, or lower actuator?
Are you sure the ignition rod is engaged in the switch correctly? If not, it can bind against the column.
annaleigh
18
Jan 14, 2017 01:08 PM
Marcasium
May 5, 2016 05:31 AM
GM4WALLS
Nov 28, 2015 10:20 AM
Vinny1234
Nov 9, 2015 02:02 PM
jacksheerin
Jun 27, 2015 03:21 PM
