gas mileage help
Old Jan 14, 2003 | 10:43 AM
cek181's Avatar
cek181
gas mileage help
i need all the suggestions i can get. when i bought the truck i was getting 14 miles to the gallon, now im down to 8-9 after less than 1000 miles of driving. 302, auto, 3.31 gears, 31x10.50 tires. i changed the fuel filter and air filter and pcv valve. where else should i start looking? would my cats being clogged have that much effect on it? or are the tires too big for the gearing? it sucks when im getting the same gas milelage as my buddys dumptruck with a carburated 460 in it
Old Jan 14, 2003 | 10:56 AM
Cbike9's Avatar
Cbike9
Post gas mileage help
If tou put the big tires on it then that is a major factor that brought it down, the gears don't like the big tires. I hate making that choice big tires or good gas milage, it sounds like you have another problem also but cats usually take quite a while to get backed up.
Old Jan 14, 2003 | 11:23 AM
PATS2002's Avatar
PATS2002
gas mileage help
Recalibrate your speedo(psom) there is an article in the tech article section. and go to tirerack.com to find the specs for your tires. I did on my 94 made a big difference
Old Jan 14, 2003 | 11:51 AM
Pastmaster's Avatar
Pastmaster
gas mileage help
Also check for any error codes. Ford engines typically get pretty poor mileage when an error code is present.
Old Jan 14, 2003 | 02:13 PM
cek181's Avatar
cek181
gas mileage help
if i bumped up my gear ratio to 3.73s or so to put everything back in factory spec, would that help? since it would be running at optimal performance....
i had plans of going straight axle and 9 inch with 4.56s and 35s or 36s but thats on hold right now if im getting this kind of mileage....
Old Jan 14, 2003 | 04:24 PM
mrwizard's Avatar
mrwizard
gas mileage help
Your gear/tire combo is probably not the cause, unless you changed the tires yourself, and saw the mileage drop after that. There have been a few posts regarding calibrating speedometers lately. Give yours a check, it could be off a bit if your truck came stock with 235/75 tires. Poor mileage can be caused by any number of things, but start with the easy stuff and make sure the tires are inflated properly. Low air pressure in the tires can literally suck the gas right out of the tank. Well, not really, but it seems like it.
BTW, where did you get the beautiful girl riding shotgun? I've looked in all the catalogs, and can't find one listed anywhere.
Old Jan 14, 2003 | 08:29 PM
cek181's Avatar
cek181
gas mileage help
yep truck came with 235s and i put on 31s. going up 2 inches in height i don't think would make my mileage drop from 14 to 9 though.
i also started having the problem after my front fuel tank was replaced because it had a leak in it. since then i changed the fuel filter but like i said that didn't help much. i also have begun to notice my fuel pump being louder than normal. if i stand next to the truck i can hear it running under there. is something wrong there?
Poor
>seems like it.
yea they are aired up good.
im wondering could it be a problem with the computer making it burn much richer than its supposed to?
>anywhere.
its a secret. the good ones worth taking for a ride are getting hard to find these days.
Old Jan 14, 2003 | 08:45 PM
PATS2002's Avatar
PATS2002
gas mileage help
[updated:LAST EDITED ON 01-14-03 AT 09:47 PM (EST)]No but it will give you an accurate base line as far as what kind of mileage you really are getting. If you are off a few mph's so is your odometer. Also do you live where the use of oxygenated fuel is used in winter ?? Makes a difference for me mileage wise.
Old Jan 14, 2003 | 09:54 PM
tnmale46's Avatar
tnmale46
gas mileage help
i baught a 94 with a 5.8 in sept. it was getting about 15 mpg it droped to about 8-9 was losing power also it was the cats replaced them now get about 16 mpg good luck
Old Jan 15, 2003 | 10:17 PM
cek181's Avatar
cek181
gas mileage help
im gonna redo the entire exhaust first chance i get well see if that makes a difference. could the be with the engine burning way too rich because of a sensor or computer problem?
Old Jan 16, 2003 | 03:44 PM
moonshot314's Avatar
moonshot314
gas mileage help
what doy ou have to do to check error codes? what kind of error codes might be found that would gas bad gas mileage?
Old Jan 16, 2003 | 04:30 PM
steve83's Avatar
steve83
gas mileage help
stan 951
Mar 2, 2010 03:51 AM
Manwith3fords
Jan 6, 2007 08:42 PM
gonetruckin
Apr 23, 2006 08:46 PM
Kista20
Feb 23, 2005 10:18 PM
scout_ii_4x4
Aug 23, 2003 04:14 AM
