Possible Head Gasket ??
Old Dec 8, 2010 | 06:02 PM
jhinalabama's Avatar
jhinalabama
I'm thinking HG, the trucks got a EGR cooler delete, EGR delete, new oil cooler. It builds enough pressure in the cooling sys. to make the cap bleed off. If you watch the degas bottle with the cap off and engine up to temp. You can see what looks like the coolant peculate. Looks like air bubbles coming out of the hose attached to the bottom of the degas bottle. Temps are ok when driving, no water oil mixing. Any thoughts thanks for the help.
Oh ya its an 05 f350 6.0L 170,000 mi
Old Dec 8, 2010 | 07:06 PM
cheezit's Avatar
cheezit
see tsb 09-08-03
also try a cap first its much cheeper then headgaskets
Old Dec 8, 2010 | 07:14 PM
tylertx2010's Avatar
tylertx2010
wanting to bulletproof ?
in need of egr delete arp studs and head gaskets to be replaced, if head gaskets are not blown or damaged can the studs be replaced without removing the heads maybe one at a time or is this a bad idea i need a diesel tech to take on my truck or im thinking bout settin it on fire
Old Dec 8, 2010 | 07:15 PM
cheezit's Avatar
cheezit
if your having issues please start a new thread. someone will gladly help you.
remove the headbolts equals remove the heads and replace the gaskets.
Old Dec 8, 2010 | 07:16 PM
tylertx2010
brand new egr valve and i still smell coolant in the cab ?blown gasket or just bad cap on overflow
Old Dec 8, 2010 | 07:28 PM
jhinalabama
Originally Posted by cheezit
see tsb 09-08-03
Thanks cheezit i'll try it.
Old Dec 8, 2010 | 07:30 PM
jhinalabama
You need to spend some time in the tech. threads
Old Dec 9, 2010 | 09:14 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX
I had the same issue and the same symptoms on my '04. No mixing of any fluids, just way too much pressure in the degas bottle and coolant loss there, especially when pulling a heavy load, lots of boost.
Bubbling in the degas bottle.....head gaskets.....which really means head bolts. Get those ARP studs in there, sooner the better.
Just my experience, a lot of reading here on the forum, and a confimation by the Ford stealership.
Old Dec 9, 2010 | 09:18 AM
jhinalabama
Thanks for all the help guys. Where is the best place to get an engine gasket kit and arp studs.
Old Dec 9, 2010 | 12:32 PM
TheBestKindOfEX
There was a post here in the 6.0 forum where someone told the cheapest source. It was under $400. I paid $415 delivered.
Do a search for ARP studs and I think you will find the cheapest source. My total DIY parts was $1450. I have a post that spells out all my costs and sources. BTW I really did not need to spend the money on the Black Onyx gaskets, everyone says the factory ones are just as good. Check out Partsguyed.....and SEARCH and READ! Search is your friend.
Old Dec 9, 2010 | 01:27 PM
lawnboy1965's Avatar
lawnboy1965
Cheapest ARP studs by 3 bucks. Rollin Smoke Diesel. 2003-2007 Ford 6.0L Powerstroke ARP Head Stud Kit
Old Dec 16, 2010 | 12:53 PM
jhinalabama
Well I got it tore down and the heads are at the machine shop. Now i'm just waiting on all my parts to show up. Got my stuff from Rockauto.com and ebay. Hey anybody got a fuel injection wire harness.
Old Dec 16, 2010 | 06:31 PM
2006powerstroke90's Avatar
2006powerstroke90
Id assume your doing all the work yourself?
Cab still on or off? How hard is it? Any pics? Lol
I found this on eBay, not sure if its the right one though, just tryig to help.
NEW 03-07 FORD 6.0 DIESEL INJECTOR HARNESS SAVE $300 - eBay (item 170576106102 end time Jan-05-11 06:54:27 PST)
Goodluck
Old Dec 16, 2010 | 09:09 PM
jhinalabama
Goodluck
The cab is still on. It is a pain in the a** ... I took some pics but something was wrong and they didn't turn out. I'll take some more during install. The machine shop said that every cylinder was leaking. Thanks for the ebay fined.
Old Dec 19, 2010 | 08:28 PM
jhinalabama
Getting my Heads from the Machine Shop in the morning. Got most of my parts in, enough to start putting it back together any way. I'm going to try to get some pictures posted soon. This is an after thought but has any body else have this problem. I had to pull the 4 back out side HD bolts with the head, there was no way they were coming out first. I pulled the A/C dog house side cover off to aid in some more room. This was on the pass side. Any thoughts on this. Thanks
