Don't know where to start....
Old Dec 29, 2010 | 07:32 PM
carrcreekcaller's Avatar
carrcreekcaller
Thank you Les. Yes, I know where the camshaft positioning sensor is, right front of engine block above the crankshaft's harmonic balancer. Truck ran fine till it rained late this morning.
As far as I know the back pressure sensor has not been disconnected. If I don't change the sensor (I'm just assuming it is faulty) will I have any problems.
Old Dec 29, 2010 | 08:19 PM
carrcreekcaller
Just searched and read this thread:
https://www.ford-trucks.com/forums/9...-skipping.html
I'll start checking the inboard side of the engine for chaffed wires tomorrow, as I have checked the drivers outside of engine block and found nothing bad.
I'll keep ya all posted on my progress.
CCC
Old Jan 12, 2011 | 02:04 PM
Colbybet's Avatar
Colbybet
Similar issues
I have a 1999 F-250 SD 7.3 L PSD. I recently changed the glow plugs and glow plug relay (1-8-11). After changing them my truck starting running rough. The check engine light is on. I took it to a local diesel mechanic and he hooked it to his code reader and code P1316 came up as well as P0603. He reset the codes and started my truck and the P1316 code came back up. he suggested it was the CPS. I have had it changed (year or two ago) due to recall. Could this be my problem?
Old Jan 12, 2011 | 02:22 PM
Kwikkordead's Avatar
Kwikkordead
I guarentee you that one of the injector plugs has come loose. It's easy to do when re-installing the valve covers. For me it's #1 injector that gets knocked off.
When that happens you have a dead miss and a P1316 IDM code.
Been there done that.
Old Jan 12, 2011 | 03:49 PM
Colbybet's Avatar
Colbybet
Thanks. I'll have to give that a look. All I have to do is push it back down?
Old Jan 12, 2011 | 04:16 PM
onelionhunter's Avatar
onelionhunter
push it on
Push it back on, and make sure all of the wires are tucked away from the rockers etc. Also, did you do the 50 cent mod while you were in there, or put the Ford retaining clips on? The main harness is prone to coming loose with these as well.
Old Jan 12, 2011 | 04:18 PM
Colbybet's Avatar
Colbybet
I didn't do any modifications while I was in there. Probably wont get it until tomorrow night while at work at the Fire Station. What do I need to do? And what do I need to get?
Old Jan 12, 2011 | 04:23 PM
onelionhunter
Link
Look at this link, post 2 and 8, it should help you out.
https://www.ford-trucks.com/forums/8...ck-shakes.html
Old Jan 12, 2011 | 04:33 PM
Colbybet's Avatar
Colbybet
HAHA. I see now. Yeah I will do that while I am in there. Thanks for the help.
Old Jan 12, 2011 | 06:43 PM
F350-6's Avatar
F350-6
It's not really push it back down. Shimming the connector while you're in there is a great idea, but your issue is most likely a plug on one of the injectors. Look for the white plastic plug on the inboard side of each brown square (injector solenoid). The connector actually pushes up into the injector solenoid and there is a wire clip that you flip up to lock it in place.
Old Jan 12, 2011 | 07:21 PM
Kwikkordead
^^^^ What Chris just said. ^^^^
Old Jan 14, 2011 | 10:43 AM
Colbybet's Avatar
Colbybet
Thumbs up
Thanks for the help everyone. Tore into last night at work and as soon as I removed the valve cover I could see the wire unplugged. Easy fix! And cheap too!! Again thanks for everyones help.
Old Apr 30, 2012 | 09:42 AM
  #28
carrcreekcaller
Looks like I never replied to the thread I started on solving the problem. I since I search the threads thought I'd finish what I started. The cutting out was caused by the intermittent wipers being used. Wipers would through a code and the cps would pick it up and cut off the engine. Replaced the Ford cps with an international and the problem was solved.
ccc
nhredneck
2004 - 2008 F150
Feb 3, 2018 11:39 AM
jamers
Apr 27, 2017 02:47 PM
chevy305dbt
2004 - 2008 F150
May 19, 2013 12:18 PM
Trailblazed
Modular V10 (6.8l)
Dec 26, 2006 08:06 AM
Jeff T
Mar 25, 2004 02:27 PM
