axle code???
Old Mar 2, 2003 | 09:01 PM
i looove fords's Avatar
i looove fords
Question axle code???
hi everyone..i've been trying to figure out what front axle i have for a while now and this is the only number i can find under all the oil and grease (c385) does this mean anything?? any help would be much appreciated....
thanks..
mike
Old Mar 2, 2003 | 09:09 PM
Boss_358's Avatar
Boss_358
axle code???
What kind of truck is this on?
Old Mar 2, 2003 | 10:00 PM
i looove fords
axle code???
sorry..it's on a 1979 ford F250 4x4
Old Mar 2, 2003 | 11:19 PM
heep70's Avatar
heep70
axle code???
Look on the front of the drivers side axle tube. There should be six numbers a "space" then a letter or number. Call a gear shop "Randy's Ring and Pinion" 1-800-292-1031. They can tell you what size axle and year it is.
As far as what is inside of it, there should have been a tag on the inspection cover with numbers and letters. If not you might have to open it up. I would say it probably has an open carrier unless some 4Xer put some sort or clutched locker or locker in it.
Toyman
1978 - 1996 Big Bronco
Jan 28, 2015 09:13 AM
DazedNCornfuzed
Offroad & 4x4
Feb 6, 2008 09:11 PM
92ford150
Nov 3, 2006 07:42 AM
nixon_ca
Feb 13, 2005 12:57 AM
Ryan50hrl
May 29, 2002 08:48 PM
