Need help
Old Dec 7, 2010 | 11:09 PM
bobbyt89's Avatar
bobbyt89
Need help
Iv got a 96 bought it in real bad shape working on fixing it up iv replaced the glow plug relay 4 driver side glow plugs done the 6637 mod ccv mod and fuel filter change and oil change.
i bought the truck and it had power. not what it should but had some now it has none idles rough will not start cold! and when it reves it sounds like theres a miss and has pufs of smoke .
im thinking bad injector but not sure any ideas thanks for anything im new to diesels dont know much
Old Dec 7, 2010 | 11:27 PM
Gagew90's Avatar
Gagew90
check the UVCH
Old Dec 7, 2010 | 11:37 PM
JamesHajek's Avatar
JamesHajek
How many miles? I would also look at the UVCH and UVC gaskets. It could also be injectors depending on how many miles the truck has on it and if those are factory injectors that have worn out. When you say it puffs smoke, are we talking white smoke, blue smoke...? Does it cold start when its been plugged in?
Old Dec 7, 2010 | 11:56 PM
oldbird1965's Avatar
oldbird1965
If it puffs white smoke and has a miss it might be a bad cylinder (rings).
Old Dec 8, 2010 | 12:00 AM
bobbyt89's Avatar
bobbyt89
it has 200000 on it what is the uvch and uvc?
Old Dec 8, 2010 | 12:04 AM
Gagew90's Avatar
Gagew90
Under valve cover harness its part of the valve cover gaskets and the wires that power the injectors and GP's its possible while you were doing the driver side GP's you could have accidentally caused it to come unplugged and now have a dead bank
Old Dec 8, 2010 | 12:05 AM
JamesHajek's Avatar
JamesHajek
uvch = under valve cover harness, uvc gasket = under valve cover gasket.
Old Dec 8, 2010 | 12:12 AM
bobbyt89's Avatar
bobbyt89
white/gray puffs not constent smoke but when reved like 3 times a second a true long 1missippi second
Metz12345
Jan 19, 2015 06:48 AM
farmboy802
1978 - 1996 Big Bronco
46
Jul 22, 2013 10:56 AM
884x4broncoII
Jun 10, 2010 10:21 PM
dieselboy1988
47
Mar 30, 2008 12:26 AM
Phrogman46
Jun 16, 2004 08:40 AM
