is this normal (long post)
Old Jun 10, 2010 | 09:33 PM
884x4broncoII's Avatar
884x4broncoII
ok i recently changed injector o-rings and water pump. first thing i noticed is the truck ran much smoother reved threw the entire rpm range without any hesitation or stumbling or smoke. i did also notice injectors did sound louder though. after probably 15-20 miles of city driving i got the oil changed and topped off all fluids. then about 100 miles of mixed driving. then sense then iv done about 1000 miles of pulling a trailer threw mountain passes and working the truck quite hard.
i checked all fluids after about 100 miles of pulling, and noticed the anti-freeze level had drooped about an inch oil still looked full. toped off anti-freeze and its stayed the same sense. now in the last 200 miles (of the 1000 miles of towing) the injectors seemed to quite down a bit and power has picked up the motor is running smoother better acceleration pulling hills better, but i seem to have started using a little oil in the last 900 miles about i added a quart of oil and its just a smidgen below full. i also have some start up smoke (on cold start) witch could be due to glow plugs as i know i have a couple bad ones but i was running short on time and didn't have the cash to replace all of them so i didn't change any of them. i did not notice any start up smoke before leaving on the trip but it was a lot warmer at home when i left than what it is where i am now.
the truck still revs threw the entire rpm range with no hesitation or smoke. start up smoke goes away after driving a block or two. also i did not use a torque wrench on the injectors as i didn't look up the torque specs i just did it by feel. i think im just being paranoid but the drop in coolant level worried me a bit but probably just a air pocket as its stayed the same sense topping off.
the change in the sound of the injectors worries me although it seems to be running better but the change in sound combined with the oil consumption worries me. i also still have a little bit of a bluish tint to the fuel although more of a green color than before. and i only washed out the fuel filter in some clean diesel have not replaced it yet. im sure the filter plus residual oil threw the fuel system could be the cause of this. im hoping that i didn't maybe slightly ruin a o-ring by not using a torque wrench. although it dosent run like bad o-rings like it did before.
could the drop in oil level and change in the sound of injectors be due to an air pocket working its way out as well? when i put everything back together i just put the oil drain plugs back in the heads and put everything back together and cranked it 3 times at 20 seconds each time before it fired, i did not leave the plugs out until oil reached the bottom of them.
I will probably put new glow plugs in next month as well as put a torque wrench on the injector hold downs.
Old Jun 10, 2010 | 09:40 PM
884x4broncoII
also there is 230k miles on the truck and pulling the oil cap with it running it does appear to have a little blow by but not what i would consider excessive. iv got another 430 miles to drive tomorrow and then the return trip home in a week or so. im sure the truck will make it no problem just want to make sure everything is normlal
Old Jun 10, 2010 | 09:49 PM
Talyn's Avatar
Talyn
its rattling from lack of lubrication in the fuel.
buy some 2 cycle oil and put 1/4 of the qt in on your next tank. Put the 2 cycle in first.
They will quiet right down on ya.
Old Jun 10, 2010 | 10:21 PM
fordpride's Avatar
fordpride
X2 what he said
SaintITC
25
Feb 9, 2015 08:17 AM
g500xl
18
Apr 23, 2014 08:23 AM
Joe Bleaux
Jan 2, 2014 08:45 PM
Dutch Semi
Apr 24, 2012 05:51 AM
Pocket
82
Nov 18, 2009 08:05 AM
