302 in a highboy?
Old Dec 11, 2019 | 07:11 PM
Kubota8626's Avatar
Kubota8626
351 Cleveland
What did u use for transmission with 302. I currently have a big block c6 but will not work with Cleveland was wonder what I could u to work with divorced transfer case
Old Dec 11, 2019 | 07:57 PM
ole80grit's Avatar
ole80grit
Me? I just reused the np435 transmission. Same bellhousing bolt pattern for 300 6 and small block windsors.
Old Dec 12, 2019 | 10:45 PM
440 sixpack's Avatar
440 sixpack
Anything is possible, but that doesn't mean it's a good idea. bang for your buck a 390 is the best engine for a pickup that most often had a 360.
Old Dec 12, 2019 | 11:25 PM
SDDL-UP's Avatar
SDDL-UP
Originally Posted by Blown 331
I would go with the 351w over the 302. But I don't think the 302 is a bad choice. Ford put a 302 in an F-250 4x4 in later years so whats the difference. My dad has a 1989 F-250 4x4 and I've used it and it gets the job done.
An Explorer 302 can make 350hp with just a cam and exhaust change which I would say will be more that adequate. And they can be had cheap as well. I'd also go with a 302 WAY before a 351m/400.
With good heads (GT40 or better) a 302 can certainly make horsepower, but a 400 will make more torque and at a lower RPM.
Oaktree
General Automotive Discussion
Apr 1, 2008 07:42 PM
Old Rust Bucket
Feb 12, 2007 08:08 PM
shade1965
Dec 22, 2004 03:21 PM
335clevo
May 27, 2002 06:48 PM
