What type air cleaners and where to buy them
Old 12-06-2010, 11:48 AM
Derrick lane's Avatar
Derrick lane
Derrick lane is offline
Someone know of a good aftermarket air cleaner that has a breather hose connection that will miss the choke housing and fit under the hood. ?
My truck came with what looks like a lawn mower air cleaner with no breather nipple. thanks.
Old 12-06-2010, 02:22 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
Derrick lane,
The problem we stock 6 cylinder lovers have is that there is not too much aftermarket support for our engines. The one barrel carburetor throat is too small for most "off the shelf" breathers, unless you use an adapter. Beware though, some of the adapters are flimsy and do not seal well.
You might do well to go to the junk yard and get a filter assembly from a 1986 or older model. On the positive side, you could then have warm air directed to the carburetor to prevent carburetor icing during the cold weather.
Old 12-06-2010, 04:17 PM
Derrick lane
found one
ok i ordered a 6 1/2 " x 2" with 5 1/8 throat air cleaner from napa $13.
adapter 2 5/8 " to 5 1/8 about 1/2 " rise
spacer 5 1/8 x 3/4 "
hope it all works as i need to hook up the breather hose and pvc correctly.
Thanks.
Old 12-07-2010, 02:08 PM
Derrick lane
Adapters are plastic junk krap. Tired of wasting money on krap.
Old 12-09-2010, 10:38 AM
Derrick lane
Combination of parts = air cleaner
The adapter breather nipple broke when trying to drill it through and it still hit the choke housing. So between the lawnmower air cleaner and the adapter and some epoxy I made a base that would work with a 5 1/8 air cleaner. The air cleaner is a 6 1/2"
This is what i came up with i think it will work good but will be keeping an eye on it. And still looking for a better set up.
Old 12-09-2010, 12:18 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Classic Inlines has come out with an adapter for the smaller Autolite 1100's. Comments are suggesting one for the larger Carter carbs. We'll see.
Classic Inlines Performance Parts - Product Detail
Old 12-09-2010, 04:03 PM
parr4's Avatar
parr4
parr4 is offline
Classic Inlines has some nice looking pieces, but I don't see any provision for PVC hook-up on air cleaner...?
Old 12-09-2010, 04:14 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
That part is pretty easy. Most aftermarket cleaners come with a fitting and stamped knock out to add one. Easy to drill a hole and mount one too.
Old 12-09-2010, 04:47 PM
parr4's Avatar
parr4
parr4 is offline
excellent. I bookmarked that site.
Old 12-10-2010, 10:24 AM
Derrick lane
The biggest problem i had finding an air cleaner is the choke housing is 7/8" higher than the carb throat . So the cleaner base has to rise 1 " above the part that goes onto the carb throat. And then the hood clearance is the other issue. I have the one i made on and it seems to work good the breather is finely doing what it is intended to do. And no more condensation in the crank case/ dip stick tube. The air cleaners on the site classic in lines would not work without a spacer to raise the cleaner base. But they look good.
Old 12-10-2010, 10:34 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Here is the link to the discussion about the adapter on fordsix.com: FORDSIX PERFORMANCE • View topic - New air cleaner base for the 1100's
Old 12-10-2010, 02:47 PM
Derrick lane
That base would be great if it would clear the choke housing. You would still need to raise the base 1" to clear the choke housing on a carter 1bbl yf.
That was the problem i had. That darn choke housing!!.
But thanks for the reply
Old 12-10-2010, 03:53 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Hopefully he'll start making one to fit. He mainly sells for small blocks, but is trying to expand to the 300's. I have a 250ci with the Carter YF and the air cleaner base is formed to clear the choke. It's running a 2x12" diameter filter, but got no idea what it came off of, it's modified. Can't even take a pic. I have the whole engine crated up to ship.
Old 12-11-2010, 10:22 PM
Derrick lane
drive M not ship M
Old 12-12-2010, 07:59 AM
Greyf100's Avatar
Greyf100
Greyf100 is offline
i want to say 2.75" x 1/8" wall tubing will adapt your carb to the spectre "funnel" then you can mount any v8 air cleaner you want. Just cut the pipe to length and use a bit of RTV to seal between the tubing and "Funnel".
Boltgun
03-29-2017 07:01 PM
Jim and Austin
04-10-2016 04:43 PM
nosehair
10-30-2015 10:42 AM
phurst
01-06-2011 06:07 PM
firefighter0205
1999 to 2016 Super Duty
08-11-2007 02:55 PM
Quick Reply: What type air cleaners and where to buy them
