Sponsored by: Real Truck
Top Reasons Why?
Old Dec 6, 2010 | 09:32 AM
mstaser's Avatar
mstaser
Top Reasons Why?
I am looking for a list of some of the reasons cold weather (below freezing) can really hurt your gas mileage. Throw out the letting the truck warm up in the morning for 20 minutes. But stuff more like certain lubes need changed or any stuff that would cause a frozen truck to struggle and use a lot more gas.
I have noticed a pretty good drop in mileage since we started getting freezing temps here. I will have some time off around xmas that I planned on doing some work on the truck and am curious on a what I need to fix, lube, replace or just check out.
Thanks
Matt
Old Dec 6, 2010 | 10:49 AM
redford's Avatar
redford
FTE Leadership Emeritus
The biggest reason is the switch to a winter blend (oxygenated) fuel in most areas. You need to burn about 10% more to get the same power, so your mileage drops.
Old Dec 6, 2010 | 10:52 AM
mstaser's Avatar
mstaser
So if I get gas at a bunch of random places, I will have good tanks and bad tanks? I normally can notice some fill ups do better than others.
Old Dec 6, 2010 | 12:44 PM
sammy77's Avatar
sammy77
Nope, they all switch to it.
Old Dec 6, 2010 | 12:46 PM
mstaser's Avatar
mstaser
Are there any other items that freezing weather may cause issues?
Old Dec 6, 2010 | 01:29 PM
orng1's Avatar
orng1
The engine takes longer to warm up so the ecu stays in cold idle mod longer. It injects extra fuel to get the cat to warm up. That and a lot of other things, heater on, blower full blast, defrost, oil is thicker. It all adds up.
MFW
Mar 6, 2014 09:50 PM
ronwcu04
Nov 18, 2010 08:20 AM
DrFord
Oil & Lubrication
18
Mar 22, 2010 11:47 AM
matt12
Jan 14, 2010 04:31 PM
Beast12
Oil & Lubrication
15
Jul 4, 2003 11:02 AM
