Sponsored by: Real Truck
Radio...What tool needed?
Old Oct 30, 2010 | 03:43 PM
New2Fifty's Avatar
New2Fifty
For removal of the Nav/Radio in my 2011 SD? Need to add a Loc-Pic unit. did it in my 2009 Jeep Wrangler, piece of cake removing the trim and no tools required. The SD looks..IS put together a lot better. Anyone done it? trim and radio removal, that is?
Old Oct 30, 2010 | 04:20 PM
redford's Avatar
redford
FTE Leadership Emeritus
I know on my '07 the dash trim just snaps on. removing exposes the fasteners for the radio, but can't say on an '11.
Old Dec 6, 2010 | 01:28 PM
New2Fifty's Avatar
New2Fifty
Thanks sarge...
Old Dec 6, 2010 | 01:46 PM
2000silverbullet's Avatar
2000silverbullet
On the '11's, you have to pry the covers up on the sync port on the pass. side as well as the 12v plug on the drivers side. You'll see a small area to get a screwdriver into. Once those are popped up, I believe there's a 7mm bolt to remove. From there, I believe it's all fasteners holding it in. It's been done though, somefolks down in the 6.7 forum have the lockpick.
Don't have mine yet (sigh...) but from what I've read, this is what's involved...
Old Dec 6, 2010 | 01:50 PM
sdetweil's Avatar
sdetweil
right.. you pop out the two lower small covers (there is a slot in the bottom edge), then remove the two anchor bolts (7mm socket),
then the shell pops off and you remove the 4 bolts on the radio
Sam
here is my doc on how to do it on an 08..(to change the radio) same setup
dfooch
Aug 24, 2010 10:25 PM
BullWapiti
Nov 10, 2005 12:44 AM
BullWapiti
Oct 26, 2005 12:35 PM
97rangerguy
Dec 29, 2003 06:19 PM
CEEJR
Oct 22, 2002 04:42 PM
