the problem i'm experiancing is that the truck will not start, it just cranks over. it statred fine this morning and the i parked it for an hour and when i came out from where i was and tried to start my truck it just cranked over. has anyone experianced this issue? please help
Check further down the list of threads. There are several people with the same problem as yours, including myself.
Check engine light came on again this morning. Throwing a P0174 & P0171. I've already replaced the pcv valve assembly and hose along with the hose that goes to the top of the throttle body to the dpfe valve. I think that is what it is called.
