Sponsored by: Auxito
Please help
Old Dec 6, 2010 | 08:47 AM
sndmn999's Avatar
sndmn999
Please help
so i have a 2002 f-150 4x4 with the 4.6 litre V-8
the problem i'm experiancing is that the truck will not start, it just cranks over. it statred fine this morning and the i parked it for an hour and when i came out from where i was and tried to start my truck it just cranked over. has anyone experianced this issue? please help
thanx
Sandman
Old Dec 6, 2010 | 09:23 AM
skinner24's Avatar
skinner24
Check further down the list of threads. There are several people with the same problem as yours, including myself.
Check engine light came on again this morning. Throwing a P0174 & P0171. I've already replaced the pcv valve assembly and hose along with the hose that goes to the top of the throttle body to the dpfe valve. I think that is what it is called.
Old Dec 6, 2010 | 02:50 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
Fuel pump is a pretty common cause of this. Do some testing first to verify though.
Old Dec 6, 2010 | 04:34 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
You will have to get somewhere where they can plug in and check the engine codes.
When the engine wont start, does it hit on any of the cylinders or try to start? Or is it just flat cranking with out hitting or poping off once?
Headviking
6.4L Power Stroke Diesel
Apr 11, 2017 04:35 AM
powerstroke1869
Oct 7, 2010 06:33 AM
Bill_T
Jun 14, 2007 09:00 AM
gixxer1
Computer Chips & Tuners
Aug 6, 2005 07:11 PM
Sean Kennedy
2004 - 2008 F150
15
Nov 27, 2004 12:57 AM
