6.0 died
Old Aug 31, 2011 | 02:54 PM
strokethis04's Avatar
strokethis04
Figured I'd update this 9 months later....it was the FICM harness.
Old Aug 31, 2011 | 05:02 PM
2006powerstroke90's Avatar
2006powerstroke90
Nice to check in and let us know what happened.
It could always help someone out.
How did the harness go bad? Chaffing?
Old Aug 31, 2011 | 05:05 PM
strokethis04
I had a P0206 code I believe it was cylinder 6 low circuit code. The truck ran fine so I let it go. On black friday it shut off completely I couldn't figure it out. So I sent it off to ford 2 weeks later they say my injector back shorted through the harness and took out 5 other injectors on top of the harness. Somehow it didn't take out the FICM though. Very weird first time I have EVER heard of that happening.
Old Aug 31, 2011 | 06:26 PM
2006powerstroke90
If it was from something shorting out, I can see how it happened, but luckily it didnt take out your new FICM
Thanks again.
Old Aug 31, 2011 | 08:27 PM
strokethis04
Yeah no problem.
Old Aug 31, 2011 | 10:20 PM
BLADE35's Avatar
BLADE35
thanks for posting the outcome
funney how electrical problems just plain suck
I burned down an alternator once and all my Dash gauges freaked out to
and the alternator In replaced it with just died to
Old Sep 1, 2011 | 07:46 AM
strokethis04
I think my alternator is starting to take a crap now as well. The voltage fluctuates according to engine rpm. Either that or the voltage regulator is gone but i believe that's inside the alternator on these..im not sure.
Old Sep 15, 2011 | 01:28 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
They are.....
Old Sep 18, 2011 | 07:17 PM
strokethis04
Yeah sometimes it will drop down to 11.8-.9 Volts with my HIDS on and heater on full blast...so I should get on that soon...
Old Sep 18, 2011 | 07:36 PM
BLADE35's Avatar
BLADE35
myvoltage will drop very breifly to 11.3-11.8 at startup with GP and stuff on
but if your stuggling to make 11.8 volts all the time or with a couple of acc on that alt is on its last leg
I just changed mine out to a DC Power Alternator and so far so good
check it out
https://www.dcpowerinc.com/
Old Sep 18, 2011 | 07:43 PM
strokethis04
Yeah I belive someone already sent me this link as well man. I will be upgrading to a decent one soon hopefully. I see the modification you made in your albums(wire upgrade). Do you have a thread on it?
Old Sep 18, 2011 | 07:53 PM
BLADE35's Avatar
BLADE35
no I dont know of a thread on it
I just ran the upgraded wire according to what DC Power specified for there 190 amp alt
Old Sep 18, 2011 | 09:10 PM
  #28
strokethis04
Oh. Okay gotcha.
fifty-two_f1
33
Dec 1, 2019 08:20 PM
92will460
Jan 17, 2014 11:59 AM
Midwest Dually
28
Feb 22, 2011 05:53 PM
zman1942
2004 - 2008 F150
Jan 2, 2011 03:16 PM
danblackwood
Jun 10, 2010 09:40 PM
