drum brakes
Old Dec 5, 2010 | 12:37 PM
KO1960's Avatar
KO1960
drum brakes
I've got a 65 F250 Camper Special with a front shoe that was dragging. The drum has 3 slotted screw heads that I assume hold the drum on. I sprayed pene. oil and tried varioius tools that couldn't produce enough leverage. Is there a special tool or any tricks?
Old Dec 5, 2010 | 01:20 PM
63' f100's Avatar
63' f100
Try hitting the edge of it with a hammer. you wont hurt it.
Old Dec 5, 2010 | 01:25 PM
KO1960's Avatar
KO1960
Did that. It's almost as if I need a breaker bar with a right angle screwdriver. Maybe if I heated it up?
Old Dec 5, 2010 | 01:46 PM
66f-100's Avatar
66f-100
Take off the big spindle nut and remove the whole darn thing if you have to. I had to resort to that on one my front drums. Worked like a charm.
Old Dec 5, 2010 | 02:22 PM
KO1960's Avatar
KO1960
It comes off in one piece. Are you then able to remove the drum from the backside?
Old Dec 5, 2010 | 06:26 PM
patmedic's Avatar
patmedic
I have always had very good luck with a little heat (Torch) and a impact screw driver. If you don't have one I suggest you by a good one good tips are a must. Craftsman aren't bad Harbor Freight seems to twist when used. Be safe
p:s To answer your question when you do pull off the hub you still may need to remove the drum from the hub to have it machined. But you can service the brakes and bearings.
Old Dec 5, 2010 | 06:56 PM
66f-100's Avatar
66f-100
There may be several ways to do it, but I believe the correct way is to have the drum pressed off of the hub.
Old Dec 5, 2010 | 07:05 PM
KO1960's Avatar
KO1960
Thanks. I'll have to tackle it next weekend.
Old Dec 5, 2010 | 07:08 PM
63' f100's Avatar
63' f100
They say if a hammer doesn't work, get a bigger hammer
Old Dec 5, 2010 | 07:44 PM
patmedic's Avatar
patmedic
I thought KO 1960 was asking how to remove the screws that hold the drum on the hub.They don't need to be pressed (beat, drilled ,ground ,sworn at maybe). Then once you get the screws out you might have to press the drums off the hub. Be careful I just looked up drums for my 64 250 might make a difference real expensive $100 plus, unless you found some cheaper let me know please.
Old Dec 5, 2010 | 08:09 PM
garbz2's Avatar
garbz2
If you have access to a welder weld a 1/4 20 nut to the heads of the taper machine screws.
Typically the hear breaks them free. Purchase new Machine screws from a bolt jobber.
Garbz
Old Dec 5, 2010 | 10:14 PM
KO1960's Avatar
KO1960
I've got a torch, so I'll probably try that w/ an impact driver. The drums and shoes combined would be well over $200.
dlo3575
Aug 22, 2022 01:34 PM
Blackwaterforge
May 1, 2014 07:19 AM
Green Streak
Aug 24, 2007 12:16 PM
kyoung
Sep 25, 2006 04:47 PM
jemc
Feb 17, 2004 10:30 PM
