Leak at Trans Cooler Fitting
Old Dec 5, 2010 | 09:32 AM
jasonodsky's Avatar
jasonodsky
Truck is leaking at the fitting on the driver side where it goes into the radiator/cooler. From what I can tell, it is not the line but the brass fitting that the line goes into. The leak appears to be between the brass fitting and the radiator/cooler.
If I remove the line to replace the seal behind the brass fitting, how much ATF should I expect to come out as I replace the seal? Also anyone have the torque spec for this part?
I don't want to be caught without a large enough pan and have the truck bleed all over the driveway while I frantically try to button it back up.
Thanks, Jasonodsky
2004 XLT V10
Old Dec 5, 2010 | 01:36 PM
Jigger2020's Avatar
Jigger2020
did you try & snug it up a bit.
Old Dec 5, 2010 | 07:16 PM
perryg114's Avatar
perryg114
You should be able to tighten it. I think it is some sort of flare fitting. Make sure you hold the part on the radiator and the B-nut on the line.
Perry
Old Dec 5, 2010 | 08:22 PM
jasonodsky's Avatar
jasonodsky
It's leaking between "the part on the radiator" and the radiator. The flare nut is fine and in tight with no leak. Anyone have a torque spec on this? I'd hate to strip the radiator threads.
Old Dec 14, 2010 | 05:22 PM
jasonodsky's Avatar
jasonodsky
Anybody have an idea how much fluid I should plan on coming out once I disconnect the line from the cooler? I'll be doing it in subzero weather and would like to avoid suprises!
Old Dec 14, 2010 | 05:28 PM
Jigger2020's Avatar
Jigger2020
about half a quart, when the motor is shut off there isn't any pressure there, put a drain pan under it to be sure.
Old Dec 15, 2010 | 06:49 AM
tfs2403's Avatar
tfs2403
Just had a leak from the tranny line on my EX. I replaced the rubber line and only a small amount of tranny fluid came out, a regular oil pan will be more than enough for ya.
As far as the radiator part I am not sure. Good luck!
Robb
Old Dec 15, 2010 | 10:37 AM
jasonodsky's Avatar
jasonodsky
Thanks guys! Reps given. I'll tackle it this weekend.
Old Dec 15, 2010 | 01:29 PM
Jigger2020's Avatar
Jigger2020
your welcome Jason & thanks
Dirty Offio
Jul 7, 2017 10:08 PM
Buffalony
Modular V8 (4.6L, 5.4L)
Nov 27, 2016 01:19 PM
wulfman
Mar 10, 2012 07:40 PM
smashclash
Dec 6, 2010 06:16 PM
eforman1
Jun 3, 2010 12:09 PM
