FE Valve Cover Interchange Issue
Old Dec 4, 2010 | 09:59 PM
HIO Silver's Avatar
HIO Silver
These FE valve covers were given to me by my brother who has a 360FE in his Bumpside. They look identical to the ones I have on my 390FE. Embarking on detailing the engine compartment, I spent all weekend completely stripping, straightening, and painting these valve covers. They look good, right?
Problem: I attempted to swap the rusty valve cover on my passenger-side head with the replacement below but could not get the it to set on the cylinder head. I turned over the removed valve cover and discovered a PO had clearanced the oil baffle in order for it to clear the rockers and springs by removing most of the shield (see green arrow in image below).
Question: Is/Was there a difference btwn 360FE and 390FE valve covers? What about valvetrain components? The stamp on each refinished valve cover is 3_5_D2W (I think that means 3rd shift on the 5th day of some month in 1972). Can provide any insight to clear up this mystery? Thanks.
Old Dec 6, 2010 | 09:55 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That's weird. There should be no difference in the valvetrain for any of the later motors, say 1968 and up (I'm being conservative on that year, it could be basically ALL FE's, although I do remember some difference in valve covers).
Do you have a big cam that might be making more lift? Or is it hitting the rocker shaft or rocker stand bolt heads?
Old Dec 6, 2010 | 01:50 PM
427 fordman's Avatar
427 fordman
I have noticed that too as my dad has bunches of them laying around. I've just clearanced it out of my way too but don't know the differences. It's not because of the cam, it hits the rocker or a stand or something, can't remember for sure, and won't fit at all without modding. I think last time I did it is when put a set of old chrome ones on my pickup dad had around. That is if I remember right.
Old Dec 6, 2010 | 03:16 PM
HIO Silver's Avatar
HIO Silver
Yeah, really weird. The baffle hits the rocker and likely the valve spring over that area.
Okay thanks. I'm glad I am not the only one who experienced this. I was sooo dejected that it wouldn't fit after all that work to discover that it wouldn't fit that I gave up. I didn't want to mod the fresh covers since I would weld a shield back in to prevent oil from getting sucked up by the PCV (as it probably does now).
Maybe I'll just suck up and buy some Cobra LeMans valve covers... oh waitaminute... I might run into the same problem. Hmmm... the mystery continues.
Old Dec 6, 2010 | 04:02 PM
OrangeJuice's Avatar
OrangeJuice
You'd probably be fine with the Cobra LeMans valve covers. I put a set on my 390, but the only clearence issue I had was a couple of the fins on the top of the valve cover interfered with the brake booster. I simply ground a little relief notch in them to clear the booster. No problems at all now.
OJ
Old Dec 6, 2010 | 08:07 PM
HIO Silver's Avatar
HIO Silver
OJ.. thanks for the input. I might go back and weld up the already-hacked covers when the weather gets better but will definitely look into the Cobra FE covers with added confidence that they will fit.
Old Dec 7, 2010 | 06:22 AM
427 fordman
Cobra ones will fit, have 2 pairs. They are taller for the adjustable rockers and don't have that stupid baffle in there. I had the same problem OJ had on the fairlanes we run the fe in and "cocked" the master cylinder with some washers on one side to clear the valve cover.
Old Dec 7, 2010 | 02:40 PM
Moto Mel's Avatar
Moto Mel
The Cobra LeMans covers that came on the late Shelbys were Die Cast and slightly smaller than the original Sand Cast covers. I believe Ford used a smaller brake booster also for clearance. The Sand Cast covers were machined for a little more clearance on the
driver side.
Mr. Nasty
Nov 13, 2016 06:14 AM
greentruck72
27
Oct 4, 2016 03:47 PM
eclectix
24
Dec 16, 2015 08:24 AM
Zazoos
Oct 12, 2015 09:57 AM
Zazoos
Oct 9, 2015 03:40 PM
