no forward gears
Old Dec 4, 2010 | 07:56 PM
fasta1's Avatar
fasta1
no forward gears
I bought a 96 f 250 that was wrecked after having the frame staightend and new front clip i finally heard the 7.3 run all was good till i put it in gear i only had rev. it has a auto with over drive the trully believe the guy i got the truck from he said trnny was fine at time of wreck any ideas would be great thank you
Old Dec 4, 2010 | 08:08 PM
fordpride's Avatar
fordpride
Check all fuse if good then i would pull the pan and see if there is any gunk in it if not then start looking at the wire's by the driver side fender to see if any were damaged in the wreck
Old Dec 4, 2010 | 08:31 PM
RRranch's Avatar
RRranch
Well, you said you had rev. Did you put the shifter in D?
Old Dec 5, 2010 | 08:18 AM
fasta1's Avatar
fasta1
thank you i checked fuses all were good the pan on the other hand had some gunk in it it had 2 pieses that were about 2 inches long with what looked like clutch disc ground in to it not looken good thanks for your help
Old Dec 5, 2010 | 08:24 AM
fordpride's Avatar
fordpride
Time for a new tranny if you have the cash call BTS
Zolow95
1997 - 2003 F150
Feb 6, 2024 04:31 PM
CamF250Truck
WTB - Ford Trucks & other vehicles
Oct 9, 2012 08:24 PM
fasta1
Dec 2, 2010 10:44 AM
wgw
Jan 10, 2003 10:25 PM
bigheck
Apr 4, 2001 10:57 PM
