hey
how are those tires wearing?
ive got the same rims and wondered about that wide of tire on the 15x7 rim...
Actually, the truck hasn't seen much road in three years. The most it's seen was in the neighborhood. The only problem is that on a full turn, the tires rub the radius arms. But only on a full turn. You should be fine with 10.5's. Any wider is where you run into big problems.
Glad I found this thread. My brother has a set of Eagle Alloy 15x10's and brand new Yokohama Avid S/T 275/60R15's that I can get for about the same cost as a new set of 215/75R15 tires for the stock rims. What I can find online says those tires shouldn't be mounted on a tire larger than 9.5" wide.
Anyone see a problem? Wheel load rating is 2500 lb each and tires are good for 2100 each, so they aren't the weak link.
