Body squeak help
Old Dec 2, 2010 | 09:28 PM
GBuckert's Avatar
GBuckert
Body squeak help
Well after a tune-up the pickup runs a lot better now so I figured I'd start tracking down other issues.
I have a squeak that sounds like it's coming from right outside the driver's side windshield. It's not the windshield, it's more like the hood/fender/cowl area. I can see that all three do not move as one unit. The hood moves separately. Would this cause the squeak?
It is most prevalent at lower speeds with more bumps and flexing.
Any ideas? I've never had issues with the body of any vehicle that I've owned other than paint stuff so I have no idea as to where I should be looking. I thought mounts at first but then thought that they were under the body and not up top.
Old Dec 2, 2010 | 10:13 PM
garyed08's Avatar
garyed08
99% chance its the hood cowl under the wiper arms. mine does it now since i changed the wiper motor.
Old Dec 2, 2010 | 11:49 PM
88n94's Avatar
88n94
You could get a can of WD-40 and spray anyplace metal to metal you suspect, and get a can of silicone spray and spray on anything rubber you suspect. Or you could use the WD-40 on the rubber too it's not supposed to hurt rubber. If the squeak goes away, it will soon return. Then you can spray the areas one at a time until you find the squeak. Just a suggestion.
Old Dec 3, 2010 | 03:53 AM
cj06's Avatar
cj06
check the whole area for any loose bolts or cracks in the sheet metal around any bolts , missing fasteners , and check your body mounts on that side , also look for cracks around
the door hinges !
Old Dec 3, 2010 | 02:48 PM
TexasGuy001's Avatar
TexasGuy001
If you have a squeek type noise comming from the passenger side near the windshield, check to see if the corner mounting tab for the dash of broken. Its down between the lower dash and kinda behind the kick panel. Its common for the plastic tab to break. There is a metal replacement one that Ford used to offer, but its apparently discontinued now. You can repair it with parts from the hardware store if needed. This may not be your problem, but its easy to check.
Old Dec 19, 2010 | 03:23 PM
GBuckert's Avatar
GBuckert
Okay guys, I've been looking and haven't been able to come up with anything.
I thought for a short while that maybe the upper door hinge was having issues but it looks fine to me.
ImageShack® - Online Photo and Video Hosting
Any more ideas on where to look?
This is what it sounds like.
YouTube - P1040853
Old Dec 19, 2010 | 03:52 PM
cj06's Avatar
cj06
YouTube - P1040853
does it change when you turn left or right ? noise will travel ! hows your shocks ? they can squeak !
Old Dec 19, 2010 | 03:55 PM
GBuckert's Avatar
GBuckert
Nope, the noise always comes from the same place and turning doesn't seem to effect it at all.
Shocks, I honestly never thought of them squeaking. They're dirty, that's about all I know about them. The rears have been replaced with air shocks sometime in the past so it's possible that the fronts were changed too, but I don't know how to tell.
Here's some quick shots I just took of the driver side suspension.
Old Dec 19, 2010 | 04:42 PM
raptor1971's Avatar
raptor1971
It looks like you have a bug shield. My 93 had a bug shield that made noise because it was broken and hitting the hood. It took acouple of months to figure it out. My friend caught it when riding with me. In the trash it went.
also check the radiator support at the 2 body mount. My was rust out to the point there was no more mounts left. So the whole frontend moved
(hood, fenders, grill) when going down the road.
Old Dec 19, 2010 | 05:01 PM
GBuckert's Avatar
GBuckert
I do have a bug deflector. I'll look into removing it but I don't think it's making the noise. No harm in checking though.
Old Dec 19, 2010 | 06:22 PM
cj06's Avatar
cj06
best way to check shocks is to take them loose and compress by hand and leave them off and go for a drive !
93-331-29PSI
6.7L Power Stroke Diesel
Sep 28, 2015 03:32 PM
mmxchamp
1983 - 2012 Ranger & B-Series
Aug 25, 2014 01:45 PM
astocker
Jun 9, 2014 06:33 PM
89ford73
Mar 16, 2009 09:27 AM
mfeezy
Oct 31, 2003 11:04 AM
