highspeed=roughrun HELP
Old Oct 24, 2010 | 08:06 PM
firewoodtrucker's Avatar
firewoodtrucker
I have and 89 F350 with 5.8l efi engine. When I purchased the truck a few months ago (after it sat for about 5 years) it got a new rear fuel tank, new rear fuel pump, new fuel filter, also new plugs wires cap and rotor. I cleaned the IAC valve and it runs reasonably well ( idle is still a lil choppy some time) but i has only seen about 200 kms since i bought it. The problem is once it get up to about 80 kmh on the highway is feels like it is misfiring or flooding with fuel as it loses power and becomes very jerky and shutters. additionally it used approx 50 liters of fuel to travel 140 kms (not impressed) any advice is greatly appreciated as I am running out of things to try replacing to fix the problem.
Old Oct 24, 2010 | 08:55 PM
danr1's Avatar
danr1
As always with a problem like this first thing we ask you do is run the self test and check it for any stored codes, if it gets a system pass for "KOEO" and "CM" then move on and run the "KOER" test.
If you do not know how to run a self test see>Ford Fuel Injection How To Run a Self-Test
Fuel pressure, check it and verify its not to high, and it holds within 5psi of spec for 1 minute after shutting engine off.
If you find its way to high to start with or bleeds right off to zero in a few seconds for example, there are some tests aid in determining what the problem is.
Old Oct 24, 2010 | 09:03 PM
WINGNUT-'s Avatar
WINGNUT-
My '89 has been experiencing the same problems that you describe. Does it also run better when it is first started, but runs worse as it is warming up?
Old Oct 24, 2010 | 09:18 PM
firewoodtrucker
yes it is good for about the first five minutes then once it is warm it is worse, much worse....and it is much more noticeable when under load or incline
Old Oct 24, 2010 | 09:46 PM
skyfox10's Avatar
skyfox10
yeah 7mpg, I wouldn't be impressed either. You've definitely got a problem.
Running a test really help narrow things down, since at this point, we don't really know where to start.
BTW, have you made sure mice haven't made a nest in your air filter yet. For some reason, the mice around here like to do that when vehicles sit for awhile.
Old Oct 24, 2010 | 09:56 PM
firewoodtrucker
air filter has been changed....
Old Oct 24, 2010 | 09:59 PM
Dutter's Avatar
Dutter
Yeah first get the numbers ran, because with the EFI, the computers can be tricky and will run very weird if its been messed with, or just some little chip is fried, It sounds to me like it could be the TPS, that controls the throttle and air/fuel mixture and that can make it idol funny and can make the motor run with a rich fuel mixture at higher speeds and make it suck a lot more gas, But get the numbers ran and see what comes up, if you do that it can be fixed with a simple part
Old Oct 25, 2010 | 12:23 AM
WINGNUT-'s Avatar
WINGNUT-
Sound like we are having the same problem. So far I have changed the plugs, IAC valve, fuel pressure regulator, and the temp sensor. I ran the codes and I came up with about 10 different codes. One was for the EGR valve not opening properly, and the EVP was not reading right. The EVP gets its reading off the EGR. So my step is going to be changing the EGR valve.
Old Oct 25, 2010 | 12:42 AM
timbersteel's Avatar
timbersteel
You can check the operation of the EGR valve by removing it and checking to see if the plunger is operational. There could be a rupture in the diaphram, so as to not let it work correctly. IT could also be really gummed up. if you have access to a haynes or chilton manual, it will give you instruction on how to test the EVP and the EGR. I just went rounds and rounds with my SMog system. It all boiled down to damaged/faulty exhaust. Both cats shot, muffler shot.
Another operational check is with the EGR Vacuum Regulator (EVR). Link to this site for detailed information. Extremely useful.
Ford Fuel Injection EGR Vacuum Regulator (EVR)
Old Oct 25, 2010 | 08:17 PM
firewoodtrucker
tried changing the map sensor too....got a used one and no difference....when the vacuum line is off the map sensor the idle drops and when the vac line is reconnected the idle picks up again...this is normal correct?
Old Oct 25, 2010 | 08:35 PM
skyfox10's Avatar
skyfox10
I would fix the EVP first. The EVP controls the EGR valve, if the EVP is not working your EGR valve will not function correctly. If your EGR valve is screwed up, your EVP will still perform just fine.
Old Oct 25, 2010 | 09:20 PM
DIYiT's Avatar
DIYiT
You could also try checking your coolant temp sensor. When the truck is cold, it'll run better on larger amounts of fuel than it will when warm; that could explain the harder running when up to operating temp.
Old Oct 25, 2010 | 09:24 PM
firewoodtrucker
it does seem like the temp gauge is showing a lil cooler than what i think it should be
Old Oct 25, 2010 | 09:32 PM
taisa899's Avatar
taisa899
just a thought but have you checked the timing?
Old Oct 25, 2010 | 09:37 PM
firewoodtrucker
the timing runs smooth until it hits 80 kmh even then the problem is only intermittent
