Spare Tire Key
Old Dec 2, 2010 | 08:29 PM
_Me2_'s Avatar
_Me2_
Spare Tire Key
I have an 05 F250 and it did not come with a key to lower the spare. What's the best way to get a new one? Are they universal across the line or will it be specific to my truck?
Old Dec 2, 2010 | 08:45 PM
teppler's Avatar
teppler
Mine was in the glove box in a plastic pocket attached to the manual...Had to look close for it.
Old Dec 2, 2010 | 09:05 PM
_Me2_'s Avatar
_Me2_
I've searched all over for it with no luck.
Old Dec 2, 2010 | 09:07 PM
teppler's Avatar
teppler
I think they are all alike but might be wrong.
Old Dec 2, 2010 | 09:11 PM
bismic's Avatar
bismic
To lower your spare tire without a key: First remove the plastic tube (guide) get a 6 point 9/16 socket and "gently massage" it on the lock with a extension and a hammer. Re install the guide. Now you have a new style lock in the form of a 3/8 drive socket. With 2 extentions it fits a ratchet and you can use an 18 volt drill to make it even easier.
Old Dec 2, 2010 | 09:12 PM
clane's Avatar
clane
I didn't even know that I had one until a friend showed me. He found it in the glove box in a plastic pouch also.
Old Dec 2, 2010 | 09:16 PM
ljutic ss's Avatar
ljutic ss
You have to go to a Ford dealer, they have a master kit that has at least 10 different patterns. You have to try each one to see if it lowers the carrier, when you find the right tool then you order that specific one.
Old Dec 2, 2010 | 09:44 PM
bpounds's Avatar
bpounds
There are about a dozen or more different key patterns. Not all the same.
Correct. McGard makes them and will sell you one online. But they can't tell you which one you need. The Ford dealer had a master set, and we determined which code I needed. They didn't charge me for that. Then I bought it from McGard.
A lot of guys just modify it so no key is necessary, kind of like what bismic described above. You'll find a lot of threads on that in the Superduty forum. Personally I like having the key. Makes me feel better when I have to leave the truck in the airport parking lot.
Old Dec 2, 2010 | 11:52 PM
_Me2_'s Avatar
_Me2_
I like the idea of the key as well, as long as it's not a ridiculous price. Do you recall how much it was?
Old Dec 3, 2010 | 01:59 AM
bismic's Avatar
bismic
A lot of spare tires get stolen around where I live. Getting spare keys and/or using the "workarounds" that are popsted up on the internet is easy for the bad guys. If you have an expensive rim / tire, you should have another means for securing it (chain and lock). If you do this, then you can "rig up" the mechanism however is convenient for you. Just don't think the OEM keyed mechanism is all that safe ...........
Old Dec 3, 2010 | 02:11 AM
_Me2_'s Avatar
_Me2_
Agreed. I ended up taking it off tonight. I run 35s and the spare is just whatever came with the truck (I think 275/75/17 or so), so I'm not too worried about it. Thanks for all the help, guys.
Old Dec 3, 2010 | 08:23 AM
florida_1959's Avatar
florida_1959
Not sure what options you have or the actual vehicle, (reg or CC) but I searched everywhere for mine when I bought my 06 but figured it lost. Then as I was cleaning up the cab, I found it in the little pocket that is on the outside of the jack bar leather case that was behind the rear seat. I just thought I would throw that out there.
Old Dec 3, 2010 | 12:04 PM
_Me2_'s Avatar
_Me2_
Thanks. I thought it might be in there when I bought the truck, but it wasn't. I took everything out and felt along the whole bag in case it was hidden in there good, but no luck.
Old Dec 3, 2010 | 02:00 PM
skoveng's Avatar
skoveng
My '03 came with a spare tire key. The first time I tried to use it, it took me an hour of trying to get it to work before I just tried using the crank without the key.
What do you know! It worked. Mine wasn't set up to use a key. Why did I get one? Did you try using the crank without a key first? Just a thought.
(so I have a key if needed; I'll see if it has a number if anyone is intersted)
Old Dec 3, 2010 | 02:09 PM
w_huisman's Avatar
w_huisman
IIRC, you can break the key receiver off of the spare tire crank by pounding a socket onto it and beating it back and forth till it snaps off. Then the plain end of the crank without a key works.
I did that on my previous 2003.
However, I have yet to do it to my 2006. Thanks for the reminder.
