Unhooking Wastegate?
Old Dec 3, 2010 | 10:37 AM
RKern's Avatar
RKern
Thanks mueckster. I am not a diesel mechanic by any stretch of the imagination but I thought by taking an old wg and soldering the hole to make it smaller would work. But as I think or stumble blindly through it I can see shortening the turns on the shaft would be more precise. I understand what kwik is demonstrating and with what you said I think I get it. I also wonder if the pcm would try to compensate for any of this. I do not have all the functions the pcm affects totally understood.
Old Dec 3, 2010 | 03:13 PM
KH85's Avatar
KH85
Originally Posted by cj45lc
Just MHO don't waste your $$ on the bighead wastegate go with the turbomaster from dieselsite, much easier to adjust & get the #'s you want
Just curious why not the Bighead?
Old Dec 3, 2010 | 03:36 PM
bama29fan's Avatar
bama29fan
not sure but it sounds like its adjustable where the big head is not...and its cheaper than the big head
Old Dec 3, 2010 | 05:11 PM
KH85's Avatar
KH85
Ok good to know ill look into it. Its low on the list rite now. Have a buddy that has one and he likes it, but then again hes a hell of a mechanic and has tweaked his to get mid 30s in boost, but IMO hes putting way to much boost to his 7.3 with OE head studs. haha
Im not lookin to get that high, I'd be happy at mid 20s! I just tell myself its not a hotrod, its a work truck!
Old Dec 3, 2010 | 05:29 PM
orng1's Avatar
orng1
I keep it unhooked, with tunes it's to smokey for me hooked up and I get the 30psi of boost when I want it.
Old Dec 3, 2010 | 06:04 PM
cj45lc's Avatar
cj45lc
What bamafan said, money & the other is much easier to adjust. I've got the bighead & wish I had the other...lol
Old Dec 3, 2010 | 09:05 PM
mueckster's Avatar
mueckster
When I had my stock turbo with ATS compr and 1.0 exh housing with the Turbo Master WG Controller, I had it set at 26-28 psi. With my 38r w/ 1.15 (no wg), I am pushing close to 40 psi. I haven't had any stock head gasket/bolt issues YET.
Old Dec 3, 2010 | 09:18 PM
KH85's Avatar
KH85
Sweet guys. So what should I expect as far as boost goes when I get my DP with the stock turbo? Tuner is high on the list, after guages, and prob hpx, frx, and AIH delete.
So should I add Clay IC boots to the list before the tuner to be safe?
mueckster: i'd love to have the mods you got, but I'm too much of a worry wort when it comes to my PSD!, (oh and im broke as it is)! Pushin 40lbs would be sweet! But like I said before...............its not a hotrod Kenny its a work truck! haha
Old Dec 3, 2010 | 09:29 PM
mueckster's Avatar
mueckster
The IC boots would be a good idea. I roughed up the ends of the IC pipes with some 36 grit sandpaper to give then a little more bite. They are holding the pressure just fine.
Old Dec 4, 2010 | 08:03 AM
damicofuel's Avatar
damicofuel
Hay Muckster, good tip on roughing up the IC pipes for more grip! Thanks
Old Dec 4, 2010 | 09:49 AM
orng1's Avatar
orng1
I haven't had issues popping off pipes under boost with the factory coupler. See how it goes before you spend money.
jethrodean
6.7L Power Stroke Diesel
Apr 2, 2017 06:17 AM
jstihl
Nov 14, 2016 03:14 PM
jstihl
15
Apr 23, 2016 07:59 AM
Nolo263
Oct 1, 2015 07:55 AM
hndamxmn
Jul 5, 2009 09:12 PM
