Unhooking Wastegate?
Hey guys I was just wondering what would happen if I unhooked the lead to my wastegate? Would there be any benefits? Higher boost? Or would it cause more problems than it would do good for the truck?
Just kinda curious, seems like I remember some guys doin it. Thanks in advance.
Also just so you know I dont have guages yet so I cant monitor boost or egt's. And also I do like to err on the cautious side of things. So if its something that needs to be monitored closely then I prob wont do it. Like I said before I was just wonderin if its a simple mod that may give me a bit more boost without possible major consiquences.
I am planning on gettin a banks bighead later on down the line after some other mods, like guages haha, I need em bad I know its the next mod.
If your signature is accurate then you will not hurt anything. You will get another lb or 2 of boost at WOT, but you most likely won't be able to tell by the seat of your pants. If you have a tuner or chip, then don't do it unless you have a boost gauge and can make sure your turbo doesn't go over 25psi (which is the safe limit for a stock turbo). You won't be able to go over 25psi without tunes of some sort, though.
Watch the video and it will explain what IMO is the best way to get these turbo wastegates adjusted.
YouTube - P1060812.MOV
Adjust the length of the rod until the WG won't begin to open until it hits 12 psi.
Most likely you will be shortening it up about four turns.
Use a pair of vise grips to anchor the rod coming out of the canister or you'll twist it in the canister, don't know if that will hurt the diaphram but it pays to err on the side of caution.
on
FYI, Some of the early tuners/chips came with a "boost tube". This was a short section of tube that was connected between the red line elbow and the wastegate actuator. The tube had a tiny orifice in the side of it that allowed some of the boost pressure to escape and delay the wastegate opening. Dan's method of adjustment allows more precise control.
