1978 - 1996 Big Bronco
79 steering issues
Old Dec 1, 2010 | 05:29 PM
str8piped79's Avatar
str8piped79
Question 79 steering issues
I recently pick up a running 79 bronco for $500. Everything works fine and it runs like a beast, but whenever I try to turn left it seems like the power steering goes out, the pump whines and the fluid looks frothy with bubbles. Is there air in the line and would that cause it to lose ps? Also if that's the case is there an easy way to fix it? Thanks for any help.
Old Dec 1, 2010 | 09:22 PM
RustyShackelford's Avatar
RustyShackelford
jack up the front end and turn it back and forth a lot. if that doesnt do it, get a new pump
Old Dec 1, 2010 | 09:50 PM
str8piped79
I've heard of that haha. Does that sound like what it is though? Or could I adjust the steering box..?
Old Dec 1, 2010 | 10:04 PM
RustyShackelford
If it is the box, you will need a rebuilt one
Old Dec 1, 2010 | 10:38 PM
husker's Avatar
husker
What Rusty said about jacking up the front end may help if they let the reservoir get low and then added fluid. I had the problem with my 78, and did the jack up and turn the wheel lock to lock about a 1/2 dozen times and it went away. Just keep an eye on fluid level in the pump reservoir. My power steering system leaks, so I have to add fluid occasionally. Since it isn't a daily driver and mostly gets beat around off road it isn't a big deal for me.
Old Dec 2, 2010 | 08:29 AM
str8piped79
I'll try that today, I'll let y'all know what happens. I wouldn't worry about it, but I'm trying to make it my dd so I gotta turn left Sometimes haha
Old Dec 2, 2010 | 12:30 PM
str8piped79
Well I jacked it up, turned the wheels, but still hard turning to the left:/
I'm gonna try a new ps pump and see where that gets me. Thanks for the advice guys.
Old Dec 2, 2010 | 03:23 PM
cps's Avatar
cps
If you find out it is the box i have a rebuilt one with about 5000miles on it just sitting here. Nobody seems to want it because of the cost of shipping although i am giving it away(no longer have the bronco, now an F350 4x4). If you are not to far away it might work if you are interested. Roy.
Old Dec 2, 2010 | 09:56 PM
str8piped79
I'm located in Palm Bay, Florida. I guess there's two kinds of pumps though? A 'ford' one, and a 'canned ham' one, that's what someone described it to me as. About how much would shipping be? I might be interested in taking it off your hands for you:]
Old Dec 2, 2010 | 10:09 PM
RustyShackelford
You will probably have the ford one. The other is rare
Old Dec 2, 2010 | 10:57 PM
cps's Avatar
cps
From where i live around 90$ Can.
Old Dec 4, 2010 | 09:19 PM
str8piped79
Thanks but no thanks, I found one for $30, I'm gonna try that when I get the change, thanks guys.
Old Dec 5, 2010 | 09:28 AM
cps's Avatar
cps
Did you find the pump or steering box for 30$ ?
Old Dec 5, 2010 | 01:58 PM
str8piped79
I found a power steering pump, the guy has two of 'em. I put lucas ps fix in it today, and it actually worked for a couple minutes but then I lost my ps altogether.
Old Dec 5, 2010 | 05:28 PM
cps's Avatar
cps
Yea, i did not think you could get a steering box for 30$. This one ii have still has the pitman arm attached.
