Track bar bolt broke
Old Dec 1, 2010 | 03:33 PM
villestrip's Avatar
villestrip
Trackbar bolt broke and dealer said they don't have one and if I wanted one I'd have to order a pack of 4 since that's what they come in. Anyone know a better place to get one. Thanks.
Its the bolt that goes through track bar at the frame side. The one you have to torque to 405 ft/lbs.
Old Dec 1, 2010 | 06:12 PM
Mich6.0's Avatar
Mich6.0
Find abolt supply shop and get a grade 8 bolt to replace it.Measure the other bolt for the correct length and might want to pull the traction bar down to get the proper bolt,if the bolts are like the ones on the sway bar loinkage they are an odd size.
Old Dec 1, 2010 | 07:07 PM
cheezit's Avatar
cheezit
try partsguyed. he can be found using the search function.
Old Dec 1, 2010 | 08:24 PM
villestrip's Avatar
villestrip
I was able to find one at the dealer 40 miles away. So I drove there and got one.
On another note I need to take my truck in cause I got exhaust smell in the cab. So I asked about them having a torque wrench that went to 405 ft/lbs. They said they didn't they just put a big breaker bar with a jack handle on the end and get it as tight as they can. Kind of disappointing that they don't have a torque wrench that goes that high. You'd think they would since that is the torque that Ford calls for. Just a thought.
Old Dec 2, 2010 | 06:31 AM
DJR96's Avatar
DJR96
Wink
If I remember rightly, that's a grade 10.9 M18. A serious bolt for a serious job. I wouldn't replace it with anything lesser grade at all.
How the hell did you break that??
Old Dec 2, 2010 | 10:08 AM
villestrip's Avatar
villestrip
I have a torque wrench that only goes to 300 ft/lbs. So I just went past that and it sheared the bolt. Boo
Old Dec 2, 2010 | 10:14 AM
MobeyDick's Avatar
MobeyDick
The lower Bracket broke on my 01. Broke down the length of it. 325,000 miles so i can't complain much. I just welded it back.
On the bolt, really tight works really well!
the78ranger
13
Jan 8, 2026 05:08 PM
ecampbell124
Mar 6, 2016 10:04 PM
ecampbell124
May 5, 2014 08:38 PM
