Fuel Problems
Old Nov 30, 2010 | 05:46 PM
Kirtgan's Avatar
Kirtgan
Fuel Problems
Please Help.
I have a 5.4 2001 Excursion, no mods. It was bogging down occasionally at freeway speed and idle was slightly rough. I replaced the spark plugs and boots, the problem disappeared. A few weeks later it leaves my wife stranded at the store.
It cranked fine, but would not fire. I got it home and pulled the fuel filter and it runs fine. A few days later, it won't start again. I was not getting any gas out of the pressure valve on the fuel rail. I had a second filter on hand and switched it again. It fires up, but is hard to start. Have to tap the gas pedal to get it to fire. Runs great once its going.
Could it be anything other than the fuel pump at this point? I don't want to drop the tank if there might be something simpler to try.
Old Nov 30, 2010 | 09:38 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
These are classic fuel pump symtoms. If you don't believe me throw a fuel pressure gauge on it and when it won't start or bogs or dies out you'll see fuel pressure drop. Run the tank near dry before attempting to drop tank
Old Dec 1, 2010 | 10:19 AM
Kirtgan's Avatar
Kirtgan
I don't have a pressure gauge, buy fuel and pressure at the valve seems hit and miss
JW1971
1978 - 1996 Big Bronco
Nov 19, 2014 11:09 PM
Wynn93
Nov 7, 2012 08:22 AM
cyclist7531
1983 - 2012 Ranger & B-Series
Apr 29, 2011 11:22 AM
private-aye-fish
Aug 1, 2006 11:26 AM
dpekin
May 17, 2004 12:52 PM
