Supercab on a Reg cab frame?
Old Mar 1, 2003 | 06:59 PM
taz500000's Avatar
taz500000
Question Supercab on a Reg cab frame?
I was wondering if a supercab would fit onto a regular cab frame. I believe the frame is a 78 or 79 and the supercab is a 75 or 76. Also the frame is a longbed so would a shortbed fit on it with the supercab? Any help would be appreciated.
Thanks
Matt
Old Mar 1, 2003 | 07:55 PM
ecarter50's Avatar
ecarter50
The wheelbase is different.
supercab/shortbed = 139
reg. cab/longbed = 133
Old Mar 2, 2003 | 05:43 AM
fordmando's Avatar
fordmando
I want to know the answer to this one, too, as I need a new cab and would like a supercab with the coil spring front end.
From the first reply, it appears the short bed from a supercab won't fit, but the main question still remains - will a supercab fit on a standard frame (without a bed at all, if need be?) I'm just guessing here, but the radiator support and the front cab mounts should line right up. The only potential problem is the rear cab mounts, and if the frame curves up in some way that interferes with the supercab. If it does, would a 2" body lift for the supercab provide enough clearance. If necessary, could the rear supercab frame mounts be chopped off it's frame and stuck on the regular cab frame?
Surely someone has at least attempted this swap. My idea is to just chop the necessary section out of the front of the bed, then reweld the front wall of the bed back on a couple of feet back. Instant custom Supercab shortbed.
Old Mar 2, 2003 | 11:39 AM
brown 4x4's Avatar
brown 4x4
There's a Supercab on a regular cab long wheelbase frame running around here. Real short flatbed mounted on the back. Looks kinda funny if you ask me.
Old Mar 2, 2003 | 03:32 PM
Chuky66's Avatar
Chuky66
I just got a email from a guy that has a Extended Cab 4x4 with a 460 in it for sale on Ebay. I asked him if he changed the motor out or converted to a 4x4. He replied back that the truck was a reg cab long bed, and the body was changed. I assume someone changed the motor as well then.
snowdog79
Jun 15, 2013 02:34 PM
robjs111
1997 - 2003 F150
Nov 19, 2011 09:18 PM
Aussie_F_trucker
15
Jun 15, 2011 05:06 AM
1FastGambler
Jun 8, 2011 09:55 PM
thedieselkid
Feb 10, 2010 09:29 PM
