Fuel Pump Retaining Ring
Old Nov 29, 2010 | 09:59 AM
kcmark's Avatar
kcmark
I have a 2003 Expy that needs a fuel pump change. Any advice on where to get a new retaining ring for the pump, and a good tool to remove the old one? I can not find the rings for sale doing a google search, and I can only find one universal tool to remove the old ring.
Thanks
Old Nov 29, 2010 | 10:41 AM
dirtmonkey11's Avatar
dirtmonkey11
You can do it without the special tool, all you need to use is a hammer and a very dull chisel. You have to be very careful when you are doing this, take small hits and slowly work your way around the ring. Once you break it loose then you can use your hands to take off the ring. I did the exact same thing, it isn't the best way to do it but if your in a bind and need to do the job quickly this will work good.
Old Nov 29, 2010 | 01:30 PM
alloro's Avatar
alloro
I prefer a hammer and a block of wood. Metal to metal contact can make a spark, and no one wants that when working on a fuel tank.
83sd
Sep 30, 2016 04:06 PM
money giver
1983 - 2012 Ranger & B-Series
Oct 5, 2014 11:47 AM
Farmboypowerstroke
Mar 5, 2014 11:28 AM
prettygooddeerhunter
21
Jan 13, 2011 05:02 PM
69ford99
1978 - 1996 Big Bronco
Aug 8, 2006 03:24 PM
