manual locking hub issues
Old Nov 29, 2010 | 06:04 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Wow, that could be a problem!!! I wouldn't have thought about that...
Old Nov 29, 2010 | 06:07 PM
JamesHajek's Avatar
JamesHajek
Ya me either, Its weird though because i never noticed it that close when i put that bracket on... Looks like i need to do a little modifying to the bracket..
Old Nov 29, 2010 | 06:10 PM
strokin'_tatsch
Have you run it in 4wd since you put that bracket on? I wouldn't want to modify the bracket if it wasn't rubbing before, plus those are some brackets that you don't want to weaken much at all.
Old Nov 29, 2010 | 06:12 PM
JamesHajek's Avatar
JamesHajek
I put the bracket on a couple months back and I've had it in 4wd two or three times since then. Not for very long thats why i never noticed this. You dont think some grinding on that corner will clear the ujoint to make it spin without rubbing?
Old Nov 29, 2010 | 06:17 PM
Action4478's Avatar
Action4478
Grind the bump on the joint ...
Old Nov 29, 2010 | 06:19 PM
JamesHajek's Avatar
JamesHajek
Right where its been rubbing?
Old Nov 29, 2010 | 06:52 PM
Action4478's Avatar
Action4478
You should be able to see it on the shaft, give it a little relief ...
Old Nov 29, 2010 | 06:55 PM
strokin'_tatsch
Just send me that D50 stub shaft and I will send you my D44 stub shaft. It's small enough that it won't rub I bet ya. LOL
Old Nov 29, 2010 | 07:49 PM
JamesHajek's Avatar
JamesHajek
lol, I will get it to not touch when i get home this weekend.
Old Nov 29, 2010 | 08:28 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
To also check for u-joint siezure, unlock your hubs, turn your wheels half way from center(straight ahead) to lock(turn), then crawl underneath and turn one of your axle shafts, it should turn with ease and reasonably smooth if the u-joints are in good order. If you have one that is siezing up, it will turn nice/hard/nice/hard as the u-joint is working through its angle with your tire turned slightly.
Old Nov 29, 2010 | 08:32 PM
JamesHajek's Avatar
JamesHajek
I will check that as well. Thanks for the help!
Old Nov 29, 2010 | 08:39 PM
DAVID'S97F250HD
Forgot to say, it might feel a little bit "notchy", that will be your spider gears turning.
Old Nov 29, 2010 | 08:43 PM
  #28
JamesHajek's Avatar
JamesHajek
I've done that with the tires straight ahead and they turn fine. I will check with them turned though.
Old Nov 29, 2010 | 08:45 PM
  #29
WALJON's Avatar
WALJON
This is good info thanks for posting pics of the problem James glad you found it
Old Nov 29, 2010 | 08:47 PM
  #30
JamesHajek's Avatar
JamesHajek
Thank you guys. You guys led me to it.
