rocker arm ratio?
Old Mar 1, 2003 | 01:39 PM
sargeusmc's Avatar
sargeusmc
Question rocker arm ratio?
I have a mounainear crate motor in my mustang, not sure of the year but it did come with cast iron gt-40 heads. Anyway The heads are now aluminum afr. I am in the process of changing out the cam and really need to know what ration the rocker arms are. I have a feeling they are 1.5 because each one is stamped with a "5". Thanks in advance for the help.
Rob
Old Mar 3, 2003 | 08:10 AM
swirk's Avatar
swirk
rocker arm ratio?
I beleive that you are correct. The stock rocker ratio for the gt40p heads is in a Mountaineer engine is 1.5. Most people put a 1.6 roller rockers on them. Some have even put 1.7 ratio rockers on.
Old Mar 3, 2003 | 03:26 PM
sargeusmc's Avatar
sargeusmc
rocker arm ratio?
they were not the "p" heads. Any idea on the regular gt-40 heads?
Old Mar 3, 2003 | 07:11 PM
joetee10's Avatar
joetee10
rocker arm ratio?
The rockers you have are 1.6. The stamping 5 is a ford thing and doesnt indicate the ratio. I would still swap to a 1.6 roller rocker though. Choose the lift you want with the cam and not the rocker, you will acheive better rocker arm geometry with the 1.6 over the 1.7.
Old Mar 3, 2003 | 08:10 PM
sargeusmc's Avatar
sargeusmc
rocker arm ratio?
thanks, I will be getting fms 1.6 pedestal mount
Old Mar 4, 2003 | 07:36 AM
swirk's Avatar
swirk
rocker arm ratio?
Are you sure that they are not "p" heads? Mountaineers came with gt40p heads stock. If you look at the heads are they stamped "gtp" or "gt"?
Old Mar 4, 2003 | 04:43 PM
sargeusmc's Avatar
sargeusmc
rocker arm ratio?
I'm sure they werent "p" heads, they are long since gone but my fms shorty headers bolted right up and from what I understand "p" heads require a special header.
Old Mar 5, 2003 | 07:18 AM
swirk's Avatar
swirk
rocker arm ratio?
You don't HAVE to use special headers for "p" heads. There are a couple that fit without modification. Some headers will fit if you put a small ding in a couple of the tubes, run the shorter (stock for a mountaineer/explorer) spark plugs and 90* boot spark plug wires.
My search goes on for a set of used gt40p heads.......
Old Mar 5, 2003 | 07:29 AM
Quantrex's Avatar
Quantrex
rocker arm ratio?
I wasn't aware that Ford made 1.5:1 ratio rockers for any of their engines.
Old Mar 5, 2003 | 08:46 AM
quadzjr's Avatar
quadzjr
just another Rockwell looser
rocker arm ratio?
i didn't think they did either. I thought they put either 1.6 or 1.72(boss).
Old Mar 5, 2003 | 10:49 AM
hellraiser's Avatar
hellraiser
rocker arm ratio?
1.5 is the little bow tie boys...
Old Mar 5, 2003 | 05:07 PM
sargeusmc's Avatar
sargeusmc
rocker arm ratio?
thanks to everyone for the help
Old Mar 5, 2003 | 06:16 PM
dunnit52's Avatar
dunnit52
rocker arm ratio?
1.6 rockers unless its a cobra version with the GT40's, 1.7
Old Mar 6, 2003 | 03:52 PM
swirk's Avatar
swirk
rocker arm ratio?
I know that they used the 1.5 ratio in the y-blocks. 272/292/312
flamesoldier
Dec 8, 2012 08:42 AM
cwpowell
Mar 2, 2006 07:12 PM
ford390gashog
Oct 14, 2004 05:23 PM
mooktank
Jul 11, 2004 02:30 PM
mmarmino
Jul 4, 2003 05:32 PM
