01 expedition electrical issues
Old Nov 28, 2010 | 01:04 PM
black01exp's Avatar
black01exp
i am new to the forums and expeditions. i have an 01 and have some issues i would like to get some help on. first of i have no dome lights or running board lights. the rear wiper does not work but the rear washer sprays. the windows all work with out the key on or even in the ignition. the rear heat does not get hot and the front blower motor only seems to work on high. thanks for any input you might have.
Old Nov 28, 2010 | 04:31 PM
alloro's Avatar
alloro
Are the bulbs missing from the dome and running board light sockets?
The rear wiper could be a bad motor, or if the glass open/ajar switch is stuck and the safety feature will keep the wiper motor from running. This would also keep the dome and running board lights on all the time. In turn this would've caused someone to remove the bulbs instead of track down the problem.
If the contacts of the accessory delay relay were stuck together then the windows would work all the time, as well as the radio.
The blower issue is likely a bad blower speed resistor.
Old Nov 28, 2010 | 05:07 PM
black01exp's Avatar
black01exp
i checked a few of the bulbs and they were fine but should i check all of them? do they run in a series. were is the glass ajar switch? i also was looking today and there is a fuse in the #24 spot under the dash that works my blowers is that correct i dont have an 01 owners manual i do have a 00 but it shows that spot blank. and also i can not use the rear climate control with out having the front system on if it is in the off position the rear does not work. thanks for your help
Old Nov 28, 2010 | 08:23 PM
alloro's Avatar
alloro
In 01 fuse #24 is listed as: EATC Module, EATC Blower Relay, Climate Control Switch Assembly, Feeds Fuse 7.
Download a PDF of your 2001 owners manual here:
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Dec 2, 2010 | 06:04 PM
black01exp's Avatar
black01exp
still cant get that site to work won tallow me to download the manual. any other ideas on what could be happenin with my expedition
Old Dec 2, 2010 | 08:29 PM
Turx's Avatar
Turx
Can't help with the other issues, but I don't think the rear HVAC operates without the front being on.
Old Dec 2, 2010 | 08:38 PM
black01exp's Avatar
black01exp
the year just doesn't get hot.
Old Dec 3, 2010 | 10:06 AM
alloro's Avatar
alloro
Originally Posted by black01exp
still cant get that site to work won't allow me to download the manual.
Right click the attached file and choose the save target as... option.
File Type: pdf
BubbaG7216
Jun 27, 2014 05:42 AM
MrPettis23
Jun 19, 2013 08:42 AM
whdahel
Apr 17, 2011 11:47 AM
dgray69
Electrical Systems/Wiring
Feb 11, 2010 01:36 PM
01 EXPO
Dec 30, 2005 12:03 AM
