Sponsored by: Real Truck
4x4 low range not engaging?
Old Nov 28, 2010 | 11:37 AM
roadster4432's Avatar
roadster4432
i have a 2001 f-350 psd, 2wd and 4high work fine, but when i try to shift to 4low the shift motor makes noises trying to turn to 4low but goes back to 2wd position? (i took it off and can watch it trying to get to 4low position before returing to 2wd ) i then have to pull the GEM fuse out and back in to get 4high to work again,,, do i have a bad shift motor or any other ideas???? thanks
Old Nov 28, 2010 | 11:43 AM
hammer65's Avatar
hammer65
Do you have your foot on the brake and in park when trying?
Old Nov 28, 2010 | 11:50 AM
roadster4432
foot on brake and neutral yes,
Old Dec 18, 2010 | 11:13 PM
roadster4432
Anyone else have any ideas? I would really like to get this figured out!!
Old Dec 18, 2010 | 11:20 PM
dchamberlain's Avatar
dchamberlain
Part of the shift motor is a switch that essentially reports back to the GEM the position of the motor. If the switch doesn't indicate a complete shift, the shift is reversed. My guess is that the switch that indicates 4LO is not working, so the GEM never sees the completed shift and reverses it.
I don't know if the switches can be repaired. You may have to replace the entire shift motor. You might check the shift motor connections and wiring carefully first though, to make sure there is no corrosion getting in the way.
Old Dec 19, 2010 | 09:24 AM
roadster4432
ok thanks very much this is very helpful i will examine my connections closer, and if nothing replace the motor, thanks
Old Dec 19, 2010 | 11:12 PM
aklightning's Avatar
aklightning
Try being stopped, stick it in N and stepping on the brake as hard as you possibly can. That's how I do it. You have to step pretty hard sometimes.
Old Dec 20, 2010 | 03:46 AM
SGnAZ's Avatar
SGnAZ
Replacement O-rings for Ford Diesel Engines
Bob has the part you might need
orange1954
Oct 2, 2016 10:04 AM
underdogl3
Feb 18, 2016 07:00 PM
rangerbait
May 22, 2015 08:01 AM
Pigman54
Jun 7, 2014 10:25 PM
