Holley help needed
Old Nov 27, 2010 | 11:38 PM
dm300's Avatar
dm300
Holley help needed
I have a holley 390 cfm carb on a 78 F250, 300 I6 with headers and an offy dp intake. Somewhere i am getting way too much fuel to the engine and it is sputtering and smoking bad. I have checked the float level, needle and seat, and power valve. All seemed ok but i replaced the power valve and needle and seat on the primary side just to be sure. Even with the float level adjusted way low and the idle mixture screws turned way in the truck would still sputter and spew out black smoke at idle and all throttle positions. I can't figure out where the gas is coming from. I checked to make shure the butterflies were closed and they were. I looked down the throat of the carb when it was running and didn't see any gas rushing in. When i take the carb off the bottom is soaked and the gasket and spacer is all soaked and theres gas sitting in the bottom of my intake. Where is this gas coming from? I'm not expert on carbs but i can find my way around if someone could point me in the right direction.
Thanks.
Old Nov 27, 2010 | 11:53 PM
turbotuner's Avatar
turbotuner
I would first guess the power valve. I know you replaced it,but could still be bad. What power valve are you using? How much vacum does the engine have? If not that recheck the gaskets. If they are the correct ones and not out of place you may have a cracked metering block.
Old Nov 28, 2010 | 10:51 AM
dm300's Avatar
dm300
I put a 6.5 in because that is what was in it. I also noticed when i had it apart that it had the check ball installed which is supposed to prevent the power valve from blowing out. I'm not sure about the vacuum. Its hard to measure when it barely runs. I temporarilly have a 2 barrel on. Is it ok to check with that on? I put a new gasket on the fuel bowl and metering block on the primary side and the one for the fuel bowl on the other side. The base gasket seemed fine. What other gaskets to i need to check? Somewhere the fuel is getting in underneath the butterflies
Old Nov 29, 2010 | 12:02 AM
kermmydog's Avatar
kermmydog
I can't remember which carbs had reverse idle mixture screws. In which case screwing in the mixture screws would richen not lean. Just a thought.
Craig
Old Nov 29, 2010 | 06:20 AM
dm300's Avatar
dm300
Craig
i have tried that also. It is not just at idle where my problem is. It is anywhere. Anytime the truck is running it is smoking and shuttering.
Old Nov 29, 2010 | 06:35 AM
Andysutt's Avatar
Andysutt
If a powervalve is blown, adjusting the rich/lean won't make a difference.
I'd check your baseplate gasket for leaks
Old Nov 30, 2010 | 08:56 AM
dm300's Avatar
dm300
I put a new powervalve in and the carb has the check ball installed which is supposed to keep the powervalve from blowing out. The new powervalve didn't change anything.
I will check the baseplate gasket and maybe just replace it since I have one. If i'm going that far I might just put a rebuild kit in it.
Old Nov 30, 2010 | 11:29 AM
Andysutt's Avatar
Andysutt
That checkball thing is garbage if you ask me. I installed one in an old vacume secondary carb I had and it still blew them when it would cough/backfire
I also knew a guy that bought a brand new one with the kit preinstalled and it blew powervalves as well.
Old Nov 30, 2010 | 04:26 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I'm still learning mine, but is there a chance the secondaries are opening. I put the quick change spring kit in mine and was unsure if I had lost a check ball. No help from instructions, just said "may" be a check ball. Check with "Abandoned Bronco" in the six cyl forum. Seems he was having a problem with fuel puddling.
Old Nov 30, 2010 | 05:55 PM
dm300's Avatar
dm300
There were a few things I noticed when I took the carb all apart and was cleaning it. First, the vacuume passage on the base that I had my vac advanced hooked up to was all plugged up. Not sure if that was part of my problem but i'm sure cleaning that out would help some. I also noticed a hairline crack on the metering block. It is on what I think is a passage for the accelerator pump. It is right above the power valve on the spring side. It is at a round part right before a diaganal passage goes to the bottom of the block. I would put a picture in here but i'm not sure how. Any of those findings sould like they could be the culpret?
Thanks
Old Nov 30, 2010 | 05:57 PM
dm300's Avatar
dm300
i'm pretty sure the secondaries were not opening
Old Dec 2, 2010 | 01:01 AM
turbotuner's Avatar
turbotuner
I would bet the crack is your problem.
Old Dec 2, 2010 | 01:16 AM
fabmandelux's Avatar
fabmandelux
Thanks
The cracked metering block is the most likely problem. Also, you do not want your vacuum advance hooked to the baseplate vacuum port. It should be hooked to the ported vacuum port on the choke side of the carb. Using the main engine vacuum port on the baseplate will give full advance at idle, and as you open the throttle you will get less advance.
The port on the choke side will have 0 vacuum at idle, and as you open the throttle it will deliver more vacuum to the vacuum advance.
Old Dec 2, 2010 | 11:14 AM
dm300's Avatar
dm300
Even though the crack is on the back side of where the transfer tube is for the accelerator pump you think that would cause all my problems? Seems like when the accelerator pump is not being pumped it wouldn't leak any extra gas into the metering block? I could be wrong though. I thought I had read that on the inline 6 that the vac advance should be on full vac???
Old Dec 2, 2010 | 12:03 PM
wdfp's Avatar
wdfp
If all that doesn't work, check the gasket for the power valve, check it very closely and where it seats make sure all is good there..
