HPOP Level Low
Old Apr 7, 2012 | 12:19 PM
timmyboy76's Avatar
timmyboy76
Thanks payson. Been fishing around, and looks as though, just to replace ALL these gaskets to rule any out. ANd while in there, check/replace the stand-pipe. I'm hoping it aint an oring around injector/s. Runs great with no smoke, once it does run. Weird thing is, it seemed to have happened overnight, and just so happened, once i installed the wvo system..(messing with fuel delivery).
Old Apr 7, 2012 | 12:30 PM
PaysonPSD's Avatar
PaysonPSD
Injector o-ring problem will not cause the HPOP res to leak down.
Caution:
There are 2 types of HPOP res to front cover gaskets. One without a screen and one with a screen. They are not interchangeable. If you put the screen type on a front cover that is designed for a non-screen type you can crack the front cover. Only replace that gasket with the type that came out.
Old Apr 7, 2012 | 12:50 PM
timmyboy76's Avatar
timmyboy76
O man, whatta relief, that is. You know if the top of reservoir cover seal/oring, is re-usable. I wanna check the standpipe for crack/breakage, but not leave myself stranded if that gasket needs replacing, once covers' removed.
Old Apr 7, 2012 | 12:57 PM
PaysonPSD's Avatar
PaysonPSD
No I don't. Never had that cover off.
Old Apr 7, 2012 | 01:06 PM
timmyboy76's Avatar
timmyboy76
No worries, appreciate the help/info anyway, Payson...
RickPlmr
Oil & Lubrication
Nov 1, 2022 10:02 PM
ansfdev
May 13, 2017 10:39 AM
tcjhkbjt
Dec 13, 2016 06:29 PM
agw
Sep 13, 2015 10:13 AM
ebexp94
2009 - 2014 F150
20
Apr 17, 2013 08:43 PM
