Cold air intake suggestions
If you want a reusable filter, use the AFE <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->24-91042My 7.3 come with Ford Severe Duty air filter. I put 40,000 miles on the new filter and the vacuum gauge barely move when I haul 25.000 lb with WOT for long time. Oil testing is proving the filter does perfect job.
Low restrictions, perfect cleaning job, expected 100,000 miles service from the single element ... what should I ask more for?
K&N is a great filter, but it seems to have a problem when it's placed in front of a turbo charger that is worked hard. More airflow is great, but if it reduces filtration it can kill a turbo or in extreme cases dust the entire engine. AFE stage 2 is a great filter set up for your truck. S&B also makes a great intake. The 6637 is a disposable, do it yourself set up that tends to have a drone that some don't like and others love. If the drone becomes an issue, you can build a box around the filter similar to the AFE set up to make it better. We've got plans for the box down in the 7.3 section. Be sure to scroll further down the main forum listing and find the 99 - 03 7.3 diesel section. Do some reading there and ask any more mod type questions you have about your motor. You can also get in touch with Pete down there and order a filter cover for whatever intake you decide on.
Clay, one of the sponsors here has some pretty good prices on the different options. Riffraff Diesel: Intake Kits / Filters
