I put in a new column in my 94, now I am having some difficulty's with the gear indicator, I cant seem to get it adjusted properly. I put it in park and adjust the indicator to the P and move throughout the gears and none of them seem to be right, when I put it into D I can wiggle back and forth between the N and D. Im thinking maybe something worn out in the shifter part? I still have to old column maybe I can use some parts off it, but not sure cause I went from non tilt to a tilt column. IF its not worn out parts on the shifter, could it just mean I need to adjust the shift cable down on the transmission itself?
