289 IS DONE
Old Dec 17, 2010 | 08:13 PM
  #46
arrowheadfred's Avatar
arrowheadfred
Originally Posted by SVT-F100
Sweet looking motor. the set up in the engine bay looks clean and crisp...
Do you have an IFS? if so do you have fotos of how you set up your engine mounts? and did you have any issues with pinion angles to the rear. Was that hard to set up?
I have a 302 HO in my garage that I will be placing on an IFS so I am just inquiring every possible.
Thanks
Yes i have a mustang 2 ifs.Had no angle troubles. What i did was set motor over the frame on a holt then we put the cab in place to make sure it cleared the firewall. We then welded the mounts .You will need a rear sump oil pan with the IFS.No way around that.I also had to use a 1/2 inch flatbar on top of the stock motor mounts to get it more clearance for the ifs . TCI has the IFS set up just for these old trucks. good luck and if you need more help just ask.
Old Dec 17, 2010 | 08:27 PM
  #47
SVT-F100's Avatar
SVT-F100
Great, thank u for the info.
I am guessing a holt is something u used to just set the motor on in order to mock up the cab?
I am going to start trolling the Internet for a rear sump oil pan.
How did you know know how high to put the motor? Or is it a size/height thing determines that u place it as low as you can with adequate clearance and u end up good.
I have been saving for a No Limit combo package for 7 months now and just hit my goal. It will be the IFS, Four link, tranny crossmember, boxin plates and engine mounts, power rack and a full brake kit. I CAN'T WAIT!!!!
Wish me Luck...
Old Dec 17, 2010 | 08:38 PM
  #48
arrowheadfred
rear sump
Make sure you get a dip stick with the rear sump. I didn't and had to build one.
Old Dec 19, 2010 | 12:44 AM
  #49
SVT-F100's Avatar
SVT-F100
Another item I will be sure to put on my list
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
