big engine small body
Old Nov 26, 2010 | 08:21 PM
rlee88's Avatar
rlee88
i want to take a 7.3 liter turbo diesel and put it into a car. I dont have access to an engine to get the dimensions and cant find it on the web. If anyone could tell me what the physical dimensions are that would be greatly appreciated. Also any other ideas on what bodies would work the best or any other suggestions would be helpful
Old Nov 26, 2010 | 09:30 PM
6CylBill's Avatar
6CylBill
I think this is a cool idea.
An older car would have a large engine compartment and heavier suspension.
Even with the older, heavier car's heavier duty suspension you will still need to modify the suspension.
Old Nov 26, 2010 | 09:31 PM
CJM8515's Avatar
CJM8515
I dont think it would be feasible b/c of the weight. Now a smaller 4 or 6cyl cummins would work well.
Old Nov 26, 2010 | 09:44 PM
6CylBill's Avatar
6CylBill
The 6 is very heavy too and also it's longer than the V8 diesel; it would be even harder to fit.
The 4cyl diesel doesn't make much more power than the 300 I6.
Old Nov 26, 2010 | 10:42 PM
Kapusta's Avatar
Kapusta
You'd have better luck stuffing a GM 6.2L diesel in a car. I know. It's been done.
What car would be the unfortunate recipient?
Old Nov 26, 2010 | 11:32 PM
onlya4.9's Avatar
onlya4.9
ive seen a 70' monte carlo with a 24 valve cummins on youtube.
i was thinking about doing the same thing with a 72 chevelle and make it a rat rod
YouTube - 1970 DMC Diesel Monte Carlo '99 Cummins turbo 24 valve
Old Nov 26, 2010 | 11:34 PM
countryboy2010's Avatar
countryboy2010
i dont but i have a buddy that does i will try to get ahold of him and im sure it can be done another friend of mine has a corrvette with cummins 12 valve in it
Old Nov 27, 2010 | 04:56 PM
rlee88's Avatar
rlee88
id really like to put it in a mustang body, but not sure what year body would work best. Also thought about maybe like a thunderbird or a crown vic or similar. any other ideas are welcome this is still in the idea stage. right now im workin out the kinks and putting it on paper so all help and suggestions are welcome
Old Nov 27, 2010 | 04:59 PM
rlee88's Avatar
rlee88
to 6cylbill: i agree with the beefing up the suspension im thinkin that ill take the engine and trans and rear end out of the victim part doning truck and then do some fab work to build the front end to it wont break in half when i drop the engine in it
Old Nov 27, 2010 | 05:29 PM
big-ugly's Avatar
big-ugly
Try something like a late 50's ford custom 300. Those cars were TANKS! I know, because I have a 59 in the garage awaiting a restoration. Has the original inline six in it, so I am thinking that you could stuff a cummins in one pretty easy, as they came with an inline six from the factory. Hell, I even tossed around the idea of retro-fitting my 89's 351w in it, and I know it would fit because I measured it, I would have to tweak the front frame just a little, but I know it would work.
Old Nov 27, 2010 | 05:45 PM
rlee88's Avatar
rlee88
thats not a bad idea i see what you mean ill look into it. you wouldnt happen to know the rough dimensions of a 7.3 powerstroke would you?
Old Nov 27, 2010 | 06:50 PM
fordparts429's Avatar
fordparts429
Interesting...
Old Nov 27, 2010 | 07:14 PM
kentuckyredneck's Avatar
kentuckyredneck
PLEASE don't ruin a Mustang with that. A T-bird or Crown Vic would be ok, but a 'Stang is just wrong.
Old Nov 27, 2010 | 07:59 PM
big-ugly's Avatar
big-ugly
I have no idea what the dimensions of the powerstroke are, sorry. My family has never owned a diesel as long as I have been alive. I don't think it could be too much bigger than a 5.4l could it? I mean, they stuffed those motors both in the same trucks, right?
Old Dec 4, 2010 | 12:15 AM
85e150's Avatar
85e150
Dimensions and weight would be the starting point. But it's been done with quite good results:
https://www.ford-trucks.com/forums/9...and-38mpg.html
dinosaur62
Jul 2, 2011 02:10 PM
MeerbottF100
2004 - 2008 F150
May 13, 2010 08:05 PM
knash0727
Dec 3, 2009 07:18 PM
mxhowes1
Mar 16, 2008 03:28 AM
maverick82
Apr 19, 2006 09:40 PM
